Question about Samsung WF337AA Front Load Washer
Washer failed to spin.
Washer failed during the spin cycle. It will not pump out the water or do any wash cycles. It sound like the motor is running. Broken belt??
  • Hal Burch
    Hal Burch Jul 21, 2009
    After taking things apart the drain pump had failed. The rotor on the drain pump had split in three pieces causing it not to turn. Pretty good deal for a machine that is 14 months old and supports a household of three persons and was not used for three months in 2008. Perhaps Samsung is not the way to go even though they had good reviews!!!!!!
    Problem Solver:
  • 7 Answers
There is nothing to stop anything from entering that models pump.
In the last 4 months I have replaced mine twice.
So the best advice is check your pockets for pennies.
And tha actual part is easy to replace.
Sorry.
I amtrying to contact samsung and see if they have any answer to this terrible design, but its predictably a hard road.
Posted on Aug 06, 2009
  • 65 Answers
Yeah ...most probably but could also be the tanssioner thats broken!
belt is a joke to replace
Posted on Jul 21, 2009
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Does Nothing During Spin Cycle than quits
You have a motor coupling gone.
Jan 25, 2009 | Washing Machines
Water not pumping out and spin cycle not working.
it sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Jul 02, 2007 | Kenmore 44072 Front Load Washer
Samsung WF337AA Front Load Washer Logo
654 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
