Question about Samsung 7.5 Cu Ft Capacity White Electric Front Load Dryer - DV42H5200EW/A3
Samsung dryer DV42H5200EW/A3 when turn on red lint light flashes then turns off but cooling light stays on and never doesn't dry clothes.
Is this the moisture sensor replacement?
2 Suggested Answers
  • 59 Answers
SOURCE: need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
Posted on Apr 29, 2009
Samsung dryer model number dv42h5200ew/a3 wont start just a click sound
There is a thermal overload located on the dryer heater housing. You have to remove the front panel to get to it... little bit of a job, but is doable if you google it.
Mar 28, 2017 | Samsung Dryers
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dryer blows cool, not hot, air
Clean the burner exhaust and intake vents of dust and lint. Make sure the gas is turned on to the machine. Watch the burner while trying to dry clothes--the igniter should turn red, then the main valve should open to start the burner. If the plate turns red, but no fire, the control valve assembly may need to be replaced. Is the unit under warranty? If so, you may need to take advantage. Hope this helps!
Dec 24, 2009 | LG DLG5988 Gas Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Samsung 7.5 Cu Ft Capacity White Electric Front Load Dryer - DV42H5200EW/A3 Logo
89 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
