Question about Electrical Supplies
The cables at the generator have been cut off and the control panel is missing.
I need a capacitor for a porter cable DBS1325 alternator but it is rusty and I cant read the labeling
Porter-Cable Portable Generator - Lawn and Garden Manuals
lawnandgarden.manualsonline.com > ... > Lawn and Garden Porter-Cable
Products 1 - 35 of 35 - Porter-Cable Portable Generator A02871-043-0. Porter-CableGenerator Instruction Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade ...Missing: dbs1325 ā€Žalternator ā€Žcapacitor
Sep 12, 2015 | Porter Cable Electrical Supplies
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
Brand new B&S 5000 watts generator,bought at H.D. Out of the box, set it up , checked oil level,OK!,filled with gas,OK!.started right up! ran for 5Mins to break in. Plugged in skill saw, made my cuts....
There really is not much you can do without voiding your warranty. This may be something simple like a connector that vibrated loose inside the control panel. (Alternator to contol panel inter-connect) There could also be a wire lying loose that was not connected. Open the control panel... and look for anything obviously out of place. DO NOT do anything else. After that your stuck with the warranty process of Briggs and Stratton.
http://www.briggsandstratton.com/~/media/PDF/BriggsStratton/Engine_Warranty.ashx
or 1-800-233-3723
When your at a B & S service / repair point... (store front)
Things to note .
1. Tell servicer unit is for PRIVATE USE (There is no warranty for commercial use)
2. Have proof of purchase in hand otherwise they will use the MFG date as the start point of the warranty. Many generators sit in a warehouse or on the shelf long past an implied warranty (date of mfg) Bottom line you need to have your sales slip.
There are several things I could have you do but... as the consumer the only thing you can do is perform an inspection. By opening the control panel you need to tell the servicer the only thing you did was a VISUAL Inspection...... Anything else will void your warranty.
So.. look for any obviously loose parts or or connectors. After that sadly your stuck with dealing with warranty service.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | Briggs & Stratton Briggs and Stratton...
Generator runs but sounds like it is missing. Was cutting off but opened the fuel tank vent knob and doesn't cut off like it did. Would replacing the spark plug and air filter take care of the...
You did the right thing . The troble with things like generators you forget about them till you need them gas goes bad things clog up in the fuel systems like filter . Its like putting your finger over the top of a straw in a glass of water if air can't get in then fuel can't get out of the tank to the engine. As long as its running now and you have power even if you have to loosen the gas cap just be careful with it and make sure you are venting the exhust away from the building good luck im on the east coast to
Aug 30, 2011 | Briggs & Stratton Electrical Supplies
Tv picture is always on full screen can not change it to wide screen or small screen. so side of picture is cut off so miss half off people at either side of screen and logos too tv channels missing like 5...
Do you use a satellite dish or cable? There are 2 different ways to control picture size. One is through the TV itself but there is sometimes also a control through the dish. For DISH network it is format on the remote. You may want to check if that setting is set to zoom or a setting like that. If it is, the TV control of the picture won't change anything. Email me back with more details if this doesn't solve your problem.
Feb 20, 2011 | Televison & Video
This is for the Porter Cable H650IS-W-1 Contractor Generator. It has an idle/RPM control solenoid that adjusts to the load on the generator. I can see that the solenoid works because 9VDC applied to it...
I do not think that your generator has a voltage regulator. The solenoid is for idle only when there is no demand (power being used). You can verify this by examing the governor spring /tension adjuster on the engine. Idle control switch on panel and the assembly board control the solenoid. When the assembly board fails generally the generator will function the same however there will be no idle. I have checked with Dewalt and parts are available however expensive. If idle is the only problem you may consider ignoring issue. If there is another problem with gen. please email.
Nov 13, 2010 | Porter Cable 6,500 Watt Contractor...
Installing load panel & inlet box
The bigger lugs will tighten just fine. Go that route and it will be easy to upgrade! If it seems way large when you put the wire in, strip the wire back and double it over. The # 6 may be a bit big for the 30 amp lugs. 30 amp circuit is usually # 10.
Sep 08, 2009 | Reliance Controls 50-Amp Power Inlet Box...
Generac control wires
just 4. I install generac switches and generators
Apr 17, 2009 | Generac 100 Amp 120/240-Volt Transfer...
Electrical Supplies Logo
19 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
