How do I adjust the image size to fit the screen
2 Suggested Answers
  • 136 Answers
SOURCE: Hi, the digital HD cable signal supplied image
If you are using dishnetwork there is a button that changes the "zoom" on screen...there are 3 settings. The button on the remote says "format"
Posted on Jul 08, 2009
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
I can't seem to print passport size photo on my mg6120
well depending on what program you are using to edit your photo. I know Photoshop has rulers on the top and sides of the screen so you could adjust you size that way. Or you can (in photoshop) select and preset the size you want the image to be and then open the photo, then drag and drop photo to the preset sized screen and the adjust photo to fit in the preset space.
Some other programs have adjustments to images in the top left of the screen and will say things like "crop" or "re-size" try using those tools, I know in most Windows running computers you have PAINT already installed. And the re-size tool should work for you. I will show by percent % how much you would like to re-size your image. so if you want it have the size of what you already have then type in 50% in the horizontal and 50% in the vertical and then apply and see if that's the size you need. if not then re-size again (but remember one you go 50% (or half size) you will most likely not want to go that much the next time because it will be re sizing your already 50% and then reducing that size by another 50% so 2nd and 3rd try i would go 80 or 90% each time until you have reached your size.
I could go on and on but see if that works if not let me know and i'll give ya some more options
Sep 16, 2014 | Canon Pixma Mg6120 Wireless Inkjet Photo...
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
How do i adjust size of desktop background to fit screen
If you are using Windows Vista right mouse click on an empty area of the desktop and select personalize. Click on the tab for background and there are options there to fit to screen, stretch image, tile, etc. Select the stretch image and then apply. It will make the image fit your entire desktop. If you are using Windows XP it would basically be the same steps exceot when you right click you would select properties. Hope this helps.
Aug 09, 2009 | Computers & Internet
NEED TO ADJUST THE VERTICAL SIZE OF A PANASONIC TV
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
When I scan a page and email it to someone,including myself, the image enlarges 12 times larger. How do I change the print size?
Check the resolution of your scanned pictures. I don't know what program you use to view your scanned images, but although you see what looks like the proper image size to you may actually be a reduced size so that it fits on the screen. Check the percentage of view that should be indicated on your screen somewhere, It may say something like 10%.
Since I don't know what software you are using to scan with, look in its help directory for instructions on how to adjust or reduce the resolution when you scan you images. Either that or once scanned open up your images with a image editing application and adjust the resolution there.
Mar 31, 2008 | Computers & Internet
I am unable to manually adjust the image size
change the resolution first. drop it on the computer side and see if that does it.
Apr 12, 2007 | InFocus LP 420 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
