Question about LG Kitchen Ranges
Lg electric stove. Two of the on / off buttons to control the stove top do not turn on.
  • 65 Answers
SOURCE: electric surge turned off the clock,oven but the stove top works
do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
Posted on Feb 19, 2008
huuum
  • 750 Answers
SOURCE: electric stove top and oven
Welcome to fixya.
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please remember to leave a rating before you leave
Posted on Dec 10, 2008
taran_2005
  • 10515 Answers
SOURCE: Hi we have a Thermador
Disconnect the power supply for few minutes, say 15 minutes and then turn it on. If the problem does not resolved, then it is an internal failure and needs repair. It could be a wiring issue, could be a problem with control board or ignitor. We need to troubleshoot further in order to know the exact cause.If you have an appliance repair experience, could use multimeter and would like to get this repaired, revert and we could proceed further.
Thanks and Regards
taran_2005
Posted on Nov 25, 2010
RyanFanMan
  • 342 Answers
SOURCE: Problems with my LG electric range modle no.
Thsi sounds like there is an issue with the thermal system because when it heats up it works and when it is cool it has trouble. have you tried to contact LG and see if they can get you a replecement part?
Posted on Feb 28, 2011
TheMobilian
  • 8220 Answers
SOURCE: OVEN TURNS OFF WHEN I TURN ON THE THE TOP BURNERS- ELECTRIC STOVE
That to me sounds like a breaker going bad in the electrical service panel. Probably nothing wrong with the stove.
Posted on Nov 21, 2012
I lost power for a week after a hurricane and my Lg stove reads Ncal, the burners work but the oven doesn't and every time the stove top is used the fan stays on all the time
Hello -
The Ncal error code on your LG gas range may mean there was damage to the oven control board, which is electrical. There could have been damage to the wiring.
Personal opinion: Contact an authorized LG gas range repair center and arrange for a repair technician to come and take a look at your stove.
Best wishes.
Jan 17, 2018 | LG Kitchen Ranges
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Problems with my LG electric range modle no. lre30451sw. The cook top burners have intermitent control some times they work and some times they don't. The oven bake control does the same thing. This...
Feb 28, 2011 | LG LRE30451 Electric Kitchen Range
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
LG Electric Range Oven touchpad buttons not working
The lock and unlock works well for the 4 - 5 button problem. However the "start" button failure is another problem altogether. I had this problem and found that the ribbon connector attaching the membrane switches to the circuit card (PWB) is where the problem lies. The ribbon cables (two of them) are connected by a pressure contact connector mounted on the PWB. This connection method is less than robust. the fix is to pull the ribbon from the connector, clean it carefully with a paper towel and some alcohol, and reconnect it. To remove the cable the connector has a small flange that pops up about .05 inch whn you pull on the connector. Once it pops up gently pull the ribbon cable out of the connector. To replace it just push the ribbon back into the slot on the top of the connector and snap the flange back down. I strongly suspect this connector will get dirty again every couple years as the oven vent fumes are not properly prevented from partially passing over the PWB right where these connectors are mounted.
Dec 09, 2008 | LG LRE30451 Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Kitchen Ranges Logo
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
