Question about Zenith Z56DC1D 56" Television
Zenith Z56DC1D dlp projection comes on then goes off no lights flashing on front.I have replaced bulb before when front light came on
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Posted on Jul 20, 2009
walesarumi
  • 6993 Answers
SOURCE: I have a 62 zenith rear projection dlp tv the
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Nov 10, 2011
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
Why does my zenith dlp projection tv turns off by it self
Bad bulb or bad color wheel. What lights on the front are flashing? Do you hear any loud humming or grinding?
Sep 07, 2014 | Zenith Televison & Video
Zenith tv troubleshooting
Are you sure about the color wheel and the lamp? Make sure the lamp is Osram brand or it may not work.
Aug 29, 2014 | Zenith Z56DC1D 56" Television
Zenith z56dc1d dlp tv picture works for about 1 minute then starts shaking and tv shuts off
You may want to get it in a rather warm room and or remove rear cover and use a hairdryer to warm everything up inside the Cabinet--with rear cover off look to see if the fans are dirty etc and if they all come on, if a DLP especially look at the lamp itself and the fan that cools it.
Dec 18, 2012 | Zenith Televison & Video
I got a Zenith Z56DC1D the bulb was replaced and its clean. I have blurry picture and it seems out of alignment there is a large black stripe on bottom and the top of the picture is cut off. How do I fix...
Without seeing a photo it sounds like the picture is letterbox with top and bottom black areas---if not that it sounds like a possible issue with the optical light engine the set uses to project the image on to the screen----most of this is not customer repairable.
Dec 04, 2012 | Zenith Z56DC1D 56" Television
The tv won't come on. the bottom red light flashes twice
YOUR tv does look like a dlp if it is ? then you need to start with lamp. if you replace lamp and clean vents and that don't help. then you need an electronic technition to determin whats causing your problem. J.D.W.
Jun 25, 2010 | Zenith Z56DC1D 56" Television
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith 56" DLP Z56DC1D won't turn on
Jul 20, 2009 | Zenith Z56DC1D 56" Television
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Zenith Z56DC1D 56" Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
