Question about Cell Phones
White screen white with worns - Cell Phones
Need instructions on how to fix my Motorola Rival A455's new white screen.
Since everything works fine, just the display (white screen) problem, with this, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Jun 25, 2011 | Motorola Cell Phones
How do you fix blank screens?my internal is half white,abd external is fully white
Good luck.
Nov 28, 2010 | LG enV3 VX9200 Cell Phone
So I'm turning on my inspiron 5100 and all i get is a white screen. It sounds like it's on but the screen remains blank white?
Hi Donny,
A white screen usually means the LCD panel has failed/worn out. Here's an easy way to make sure. Get your laptop to an external monitor, whether at your home or a friend's place, and with the laptop off and the external monitor off, connect the monitor video (vga) cable to your laptop. Turn them both on and then on your Dell laptop hold down the fn key down in the bottom left hand corner of the keyboard and press the F8 key up at the top. That transfers the video signal to the external monitor.
If the external monitor shows your laptops normal desktop and icons, then you know for sure the LCD screen on your laptop is worn out. If you get the same white screen on the external monitor, it means the video card/controller on the motherboard of your laptop has worn out and you can move ahead with deciding on repairs or other options.
Good Luck.
PS....if the F8 key doesn't transfer the video signal. look at all the F keys for one that says CRT or one that has a little picture of a monitor to transfer the signal.
Sep 01, 2010 | Dell Inspiron 5100 Notebook
Getting a blank white screen on Sony Ericsson F305...It was working fine two days ago and just last night and this morning I'm getting a blank white screen. I'm unable to access anything and even turning...
Good luck
Jun 29, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Nokia 2630 .The problem is White screen for 2-3 sec. then turn off .Help pls
1. Check the battery. They may be worn out and dead.
2. Next time, your screen goes blank / white, shut off the mobile voluntarily, restart the phone and press reset button.
3. This will fix the problem. Caution: You may lose all your data.
May 15, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
White screen
I wish you good luck.
May 12, 2010 | LG VX5500 Cell Phone
How do you fix the white screen on a motorola razr? I have tried to reset the battery and reboot the device, however, all i get is a white screen screen. The phone works find, just now display (very weak...
Good luck.
May 11, 2010 | Motorola Mobility RAZR V3
I856 white screen
there is nothing wrong with your screen. The problem is from the screen flex. The flex is either worn out or has disconnected from its right position.
So you need to open the phone cover and check the flex. If the flex is well fixed and the screen is still displaying white, then it means you have to change the flex completely.
This kind of problem is common with flip and slide phone. Its as a result of constant opening and close of the slide or flip phone.
Take care.
Mar 18, 2010 | Motorola Mobility RAZR V3
Screen went white
its a flex problem. The flex that connects the phone board to the screen has worn out.
This is very common with slide and flip phones. The flex usually worn out as a result of constant opening and closing of the phone.
Once you get the flex replaced, the screen would show again. Its not a screen fault but a flex problem.
All the best.
Jan 15, 2010 | Motorola Mobility i776 Cell Phone
LG Rumor White Screen
The flex cable that connects the two pieces that make up the phone are worn out or disconnected inside. you need to open it up and check it out. Go to http://www.youtube.com/watch?v=hNaCfrqqnd0
Apr 11, 2009 | LG RUMOR Cellular Phone
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
