Question about Samsung Refrigerators
Why is there water under the flex door of my Samsung rf4287ha?
  • Samsung Master
  • 5,323 Answers
Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Refrigeration System Basics Chapter 1
Why is there water under the flex door of my Samsu - door seals cracked-fridge-seals-vkiemehpceedlb3juqb40fef-4-0_0.jpg
door seals damaged door seals-vkiemehpceedlbWhy is there water under the flex door of my Samsu - drain center drain holer-vkiemehpceedlb3juqb40fef-4-9.jpgrc=
Posted on Feb 23, 2017
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: I have a Samsung RF4287HA Stainless Steel
hello, W/D here.
I found what I think is your model. All of the models in the series have other letters after the HA in your sequence, so when you go to this link, you may need to re-type your model number in to get to the right parts for your fridge.
Best regards, W/D
Posted on Feb 14, 2011
How to fix the wires on the flex zone for samsung refrigerator RF4287HA
If you live in Glendale, CA and need appliance repair service call us at (818) 714-7033 or visit our website Appliance Repair Glendale CA 818 714 7033 Glendale CA
Sep 02, 2017 | Samsung Refrigerators
Water is coming under freezer section of Samsung RF4287 bottom freezer French Door
You have a plugged evaporator (cooling coil) drain pan opening or drain line.
Feb 06, 2015 | Samsung RF4287HA
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
I have a Samsung RF4287ha Refrigerator. Water dispenser has no pressue all of the sudden and very littlre ice is being made. Changed the filter. Whats next
The freezer door switch.
It does 2 things
1 turns on the light for the freezer the other is turn off the water to the dispenser.
Jul 01, 2014 | Refrigerators
RF4287HA is constantly dispensing water without pushing the paddle. Is this a valve problem? How do I replace that part?
No, you need to replace the solenoid on the door dispenser. Check the model number again. That number is coming up as a range.
Feb 14, 2013 | Samsung RF4287HA
Refrigerators Logo
65 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
