Question about Kitchen Ranges
Change Temperature to show Celsius instead of Fahrenheit
catriver
  • 878 Answers
SOURCE: changing panel from fahrenheit to celsius
Dawn, press the refrigerator key and freezer key together for 5 seconds. It should toggle between them. Catriver.
Posted on Dec 25, 2007
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Posted on Nov 06, 2008
SOURCE: I cant figure out how to change my thermometer back from celcius to fahrenheit
Make sure that the odometer is set to miles and not kilometers. Hold the button down (while in the regular odometer setting, not the "trip odometer" setting) until it changes to miles. The temperature display will automatically change to fahrenheit. We just figured this out today.
Posted on Dec 14, 2008
erincinci
  • 148 Answers
SOURCE: how to convert celsius temperature into fahrenheit ino c++?
Try using the simple mathematics; - C: variable for the Celsius Temperature - F: variable for the Fahrenheit Temperature
F=((9/5)*C)+32
Posted on Apr 17, 2009
  • 4 Answers
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Posted on May 05, 2009
How to change fehrenheit to Celsius
Can you give us the model number and brand name of the thermometer you are trying to change? If you have a calculator you can do the math. To convert temperatures in degrees Fahrenheit to Celsius, subtract 32 and multiply by .5556 (or 5/9). Here are some examples for you:
Example: Convert 26° Celsius (a nice warm day) to Fahrenheit
First: 26° × 9/5 = 234/5 = 46.8
Then: 46.8 + 32 = 78.8° F
Example: Convert 98.6° Fahrenheit (normal body temperature) to Celsius
First: 98.6° ? 32 = 66.6
Then: 66.6 × 5/9 = 333/9 = 37° C
Apr 25, 2016 | Home
How to change F to C degrees
for fast conversion use this table:
http://www.rapidtables.com/convert/temperature/fahrenheit-to-celsius.htm
The temperature T in degrees Celsius (°C) is equal to the temperature T in degrees Fahrenheit (°F) minus 32, times 5/9:
T(°C) = (T(°F) - 32) × 5/9
or
T(°C) = (T(°F) - 32) / (9/5)
or
T(°C) = (T(°F) - 32) / 1.8
Example Convert 68 degrees Fahrenheit to degrees Celsius:
T(°C) = (68°F - 32) × 5/9 = 20 °C
Other webpages about conversion:
Fahrenheit to celsius conversion
http://www.wbuf.noaa.gov/tempfc.htm
Conversion of Temperature
Sep 23, 2015 | Refrigerators
How do I change the temperature to show Celsius instead of Fahrenheit
There should be a F or C button when you are in the temperature mode
Mar 11, 2015 | Measuring Tools & Sensors
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
Croc only heats up to 230 degrees is there a way to reset it
CHANGE TEMPERATURE SETTING from CELSIUS to FAHRENHEIT
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
Change from celsius to fahrenheit
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Feb 10, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
