Question about John Deere Garden
My fender lights on 4430 John Deere quit working. Any ideas?
I have cleaned the two grounds on the fender light with no luck. The back lights are working fine.
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
SOURCE: I have an eztrak john deere 445... quits.
The vent in your gas cap is plugged, it's a very small hole right in the center.
Posted on Jun 03, 2009
SOURCE: John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Posted on Oct 17, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
I have a Honda vtr 1000 sp1 Indicators and horn stoped working all other electronics are fine ! Is it just a fuse or the switch assembly??
Hi, Carl before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
horn turn indicators and brake light stopped working fuse ok
http://www.rc51forums.com/forums/14-2000-2001-rc51-sp1/2747-blinkers-brake-light-not-working.html
Honda VTR1000F Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTR1000SP 2 Owners Manul
Feb 21, 2017 | Honda VTR 1000 SP-2 (RC51 Motorcycles
2005 Toyota Sienna rear brake lights not working. Rear Center light works fine. I have replaced the bulbs and checked fuses. Continuity is good. all other rear lights work fine. What is the problem?
I am wondering if you have a bad ground wire.
Each tail light/brake light had a separate ground wire, that is supposed to be hooked to the ground somewhere.
If it is bad, those lights will not work.
Your center light probably has a separate ground wire.
If you take an electrical meter, test the bulbs with a meter, then stick the meter's contacts inside the socket and press the brake pedal and see if the meter shows "juice".
Often a car wreck/fender bender can break or compromise the ground wire of which I spoke.
God bless your efforts.
May 12, 2016 | 2005 Toyota Sienna LE
My scooters Right turn signal activates the hazard lights, and my instrument panel is non functional.
Hi Jason, before diagnosing any turn signal issue make sure the bulb is good and the light fuse has continuity with a test light. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue, please visit the websites below. Good luck and have a nice day. http://absolutelyscooters.net/service-manuals.html
Aug 28, 2015 | 2006 Kymco Xciting 250
Have an indicator fault - checked bulb and this seems fine
Hi, Anonymous before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Turn signals not working where all to check
Turn signals stopped working
Turn Signals NOT working
http://www.r6-forum.com/forums/73-south-west/154896-help-turn-signals-not-working.html
diagnosing and repairing turn signal problems
Apr 04, 2015 | Yamaha Motorcycles
No head lights, taillights, brakes lights.
A fuseable link comes through the fire wall. I had to solder a wire to my '92 van to keep it working after it blew. It happened a long time ago and now I'm not sure what it effected.
Nov 11, 2013 | 1991 Dodge Ram 350
Turn Signal Problem
Turn Signal Issues Fixed
YAMAHA XJ LED SIGNAL FLASHER RELAY FIX
http://www.groussin.com/multi/XV250.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
May 25, 2013 | Yamaha Xv 250 Virago S Motorcycles
When i apply my brakes my taillight does not light up like it should the wiring in the fender is brand new the taillight is new the brake switch is new
Well, if everything is new, it sounds like a bad ground. Since all of the stuff is new, it also sounds like it's a fresh built or has been repaired after an accident. Since the brake light grounds to the fender and the fender is grounded to the fender struts and they're grounded to the frame. See what I mean. Make certain that you have a good ground.
Then take a volt meter and measure the voltage going to the tail light. It should be the same as the battery. If not, there may be a problem with the brake light switch.
Good Luck
Steve
May 07, 2011 | Harley Davidson XL Sportster 883...
The tail light and brake light don't work. the bulb looks fine and the tour pack light lights and turn signal lights work.
The wiring sub-harness for the tail light assembly could have come unplugged, It usually plugs into the main harness under the seat or down beside the forward part of the rear fender. Also the wires could have been damaged under the fender back behind the tail light assembly.
Good Luck
Steve
Aug 22, 2010 | Harley Davidson FLHTCUI Electra Glide...
Headlight out, driving lights out, fog lights out... but directional front and rear lights work fine as does the brake light work fine. there just does'nt seem to be any electric going to those lights up...
ok could be a couple things here. Im having a memory issue at the moment so first Im gonna tell ya to check the light on your front fender if it has one?
If so and that light is out as well then run your fingers up the inside of the front fender on the right side of the tire. Have the wires from the fender tip light been rubbing on the tire and now are bare and shorted out?
Second at least if the fender tip light wires are ok or you dont have a fender tip light would be to simply click your hi/low beam light switch. Do you have a high beam and just not a low beam? If so its the bulb in the headlight because its blown out on the low beam side. Replace the headlight and then youll have your passing lamps and your fog lamps back as well since those circuits all get there power from the low beam circuit of the headlight. Good luck and let me know what you find.
May 30, 2010 | 2006 Harley Davidson FLHR Road king
BRAKE LITES WON"T WORK
you have a corroded ground in the back light bar..remove the rear light bar from the fender and make sure it is clean, not rusty.
Mar 10, 2009 | 1995 Honda VT 1100 C Shadow Spirit
Garden Logo
49 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
