Pin configuration cellboost irecharge - Computers & Internet
My network setup is asking for a pin number that is on my router. Obviously there is no pin number for this particular router and my network is asking for a 4 or 8 digit number. What do I do?
If its asking for a pin number I would check the sticker on the bottom of the router. it may have the router PIN you are looking for. If not trying typing in your internet browser address bar 192.168.1.1 and find the network settings and see if there is a pin set up, if so write it down or clear it to have no PIN
Feb 28, 2011 | Linksys Wireless-G WRT54G Router
I received a message about configuration wen i press enter it shows to enter pin number but i dunno what to enter i tried my pin number for mob but it didn't go thru i tried 1234 n 0000 but in vain wat...
Check the operator web page for Configuration settings, you should find the PIN there or Call the customer service, only them knows the PIN for the configuration messages.
Nov 02, 2010 | O2 Samsung SGH-E250 Cellular Phone
I have an old Magellan Meridian XL that has the power cable missing and I cannot locate another cable. Anyone know the pin configuration so I can make up a cable ? Power only, no data in and out.
Hi yakabofski!
There are TWO configurations of the pins with these units. We have the FIVE-pin config and the assignments are as follows:
Top pin- 12v
Bottom pin- ground.
Hope this helps.
Apr 06, 2010 | Humminbird Fishing GPS Receiver
CHARGING FAULT
hi friend,
step 1
Make sure you have all of the accessories. Some phones need special adapters for charging. If you're having problems fitting the charger into your cigarette lighter socket, check with your cell phone company. You may need an adapter ring.
  • Step 2 Find the right battery. Certain phones can only be used with batteries from the same company. If you are using a counterfeit battery, be aware that you may not be able to charge it with your current set up.
  • Step 3 Read the manual. Something as simple as charging a battery may take specific instructions. For example, some cell batteries need to be charged immediately while others come fully charged.
  • Step 4 Use your charger. Most cell phone chargers are easy to use plugging right into your phone and home outlet or car electrical cigarette socket. Read your manual on specific steps needed for charging your phone.
  • Step 5 Try Cellboosts. These convenient devices are disposable battery packs that plug into your phone, charging it when the charger isn't accessible. Cellboosts usually last for an hour and are not compatible with all cell phones.
  • Step 6 Go solar. This innovation allows you to charge your phone wherever there is light. Just attach your cell to a portable adapter and let the light do the rest
  • hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Televison & Video
    Phone sits on charger all day but then goes flat after 2 mins,
    This intrigued me. A 'unique means'! Although the instructions warned not to open the unit, I fearlessly went ahead and opened up a Cellboost to see what unique technologies were inside.
    Ummm. There were four small batteries joined in series (to provide the power) and a 2 ohm resistor also in series (to provide a simplistic and inefficient voltage control). Nothing else.
    Unique? No. But, the simplicity of the unit is not a bad thing, and in no way detracts from its functionality.
    Cost
    The Cellboost units generally cost the same, no matter which model type you get (the only difference is the adapter on the top, which varies to fit the different cell phone charger sockets). I've seen them for sale as low as $6 each at PCMall.com. They're also available at a growing number of electronics and phone retail outlets.
    Jun 25, 2009 | Doro 530 Cordless Phone
    Need master slave configuration
    You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
    Darko, Serbia
    Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
    P4 motherboard power pin configuration
    Order you a schematic online for your TV.Cost $45.00 and some cost as much as $150.00
    Feb 17, 2009 | Samsung HCL4715W 47" Rear Projection...
    Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
    slave is NO jumpers at all
    (Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
    (Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
    (Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
    (Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
    (Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
    (Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
    Oct 13, 2008 | Computers & Internet
    VGA Pin Configuration
    Pls find below the Pin configuration.
    Pin 1 - Red Signal
    Pin 2 - Green Signal
    Pin 3 - Blue Signal
    Pin 6 - Red Ground
    Pin 7 - Green Ground
    Pin 8 - Blue Ground
    Pin 10- Horizontal Ground
    Pin 11- Vertical Ground
    Pin 13- Horizontal Signal
    Pin 14- Vertical Signal
    Best Wishes
    Jul 22, 2008 | Samsung 793S 17" CRT Monitor
    Computers & Internet Logo
    41 people viewed this question
    David Payne
    David Payne
