Can anyone tell me the resistor color codings of R915 of this power supply board..phlips model FWD185.
  • Televison & ... Master
  • 16,404 Answers
Whole service manual is here, this page has the schematic on it: https://www.manualslib.com/manual/908283/Philips-Fwd185.html?page=23#manual
Posted on Dec 19, 2016
freetek
  • 5568 Answers
SOURCE: Resistor Values
I'm not sure if Akai has made any of the sets that carry their name; some have come from Samsung and others purportedly by Funai but when I have tried to find service information on given models, it has been a dead end regardless of who made it. The true manufacturers refuse to recognize model numbers assigned by Akai.
If you had just burned resistors, I might be able to help you but when missing, you're kind of stuck.
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Posted on Sep 11, 2009
SOURCE: Power supply AD-12014(I) two smd burned
223 both
Posted on Mar 02, 2010
  • 586 Answers
SOURCE: LG 42PG20 Plasma blew a
Once the voltage the television is connected to is very high, there is a very high tendency that the board will blow again, and it might not be as soon as you replace the board.
You will still have to replace the board, but you will try to get a board with higher capacitance on the capacitors. That way if exposed to higher voltage it wont get bad.
Also a tip is for you to get a step down transformer for your television or a stabilizer so as for the television not to be exposed to a very high current. That should help reduce the risk of having the board getting burnt again.
The screen only vents out once there is excessive heat in the unit and the fans in it are not working, then the screen can vent out.
Carefully assess all the boards on the television for any bad capacitors, like the ones that are swollen, it is not necessary for them to be bursted or smelly before they are bad, you just have to check for the ones that are already swollen.
Hope this information was helpful in solving the problem.
Goodluck
Elect_Comp
Posted on Jun 28, 2011
SOURCE: My LC-46LE620ut blew out R9137 on power supply board. Replaced resistor and then another component shorted out.Will replacing power supply board fix this problem? Where can I get a replacement power
Without seeing the board or the schematics, I can't say that replacing the power supply will fix your problem. There could be a short external to the power supply that is causing your problem. You can buy replacement parts from
Shopjimmy.com or Ebay.com
There are a few decent parts sellers on Ebay who actually offer warranties
Posted on Apr 27, 2012
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
Hi, i was given a NEC 50" plasma tv model #
What is the problem you faces with it now? If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 07, 2017 | NEC Televison & Video
Have you a diagram for the bosch charger model number d 70745 need to know what the ohms is for a resistor
If you can see the resistor then make a note on the color rings on it. If you go to a electronic supply store and tell them what the color code is they can tell you what it is rated at.Hope this helps you. Thanks
Mar 20, 2011 | Garden
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Mar 09, 2009 | Computers & Internet
Blowin resistor on my Acoustic Research S112PS
When I put an ohm-meter across it, I get 505-ohms. The color code looks like maybe green, dark brown, brown? Mine is discolored too. Green, brown, brown would be 510ohms. . .so that must be it. The tolerance band is gold, so that's +/-5% so that would explain the 5 ohm variance.
Feb 12, 2009 | Acoustic Research S112PS Subwoofer
When turn on ht-tz212 it shows protect and turnes off again
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Dec 19, 2008 | Audio Players & Recorders
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
