Question about Oster Kitchen Appliances - Others
Hello i have an oster skillet wok. When i plug in the wok, the temperature dial's light is turned on but the wok doesnt heat up, no matter what temperature i have it set on. Could you help me please?
SOURCE: aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Posted on Apr 20, 2008
  • 3433 Answers
SOURCE: Unit blows out cold air while on dehumidifier
Liz; Check for a fuse somewhere in the heat circuit. The master breaker in the house panel also
Posted on Jul 07, 2009
  • 60 Answers
SOURCE: temperature won't go below high
the tempature gauage could be broken they only cost about ten or twelve dollars at home depot or lowes if you havent already you may want to take grill apart and make sure when you turn burners up and down that the flame highth changes
Posted on Aug 16, 2009
  • 4 Answers
SOURCE: Do the thermostat contacts attached to bimetalic
Hate to write answer to my own problem, but after showing (its THAT SIMPLE folks!) the innards to my wife, showing her how contacts do not move close 'nuf together to touch until dialed to 300F, she said, why not put a block under lower stip to raise it. Was about to, when I noted top strip appears to be merely spring steel, and she was advocating propping up the thinner lower BI metalic one, which would have stopped it from flexing as it must as temp of pan changes. SO, we brainstormed it, used her little jewelry needle nose pliers and alternately bent top (spring) strip down and lower (bimetalic) strip upwards with knob set at "warm" until they were TOUCHING, but nevertheless would separate when knob turned fully to "OFF" Since this thermostat pilot light works whether hooked to a pan or NOT, we plugged it in (no danger, probe is not electrified in any way unless maybe handle is dipped in water and salt!) and saw that light goes "on" at warm, off at "off" and further, that when we set it at 200F and hold a lighter under the probe (it is just hollow metal, not a precision device, simply conducts heat to metal strip inside) it turned off properly at what we guess is pretty close to 200F. Will add an addendum "solution" comment when we return thermostat to friends pan tomorrow and cook something!! No electrical degree, just a wife who got tired of me not fixing her firends pan and started unscrewing things until I got aggravated nuf to do something w/ it. Happy New Year. "He who finds a wife finds a good thing." -bible
Posted on Jan 03, 2011
  • 230 Answers
SOURCE: The temperature on my honeywell
Just google RTH 2300 for the manual, check that the hold is not on, if it is push it to turn it off, if not read thru the manual. On most stats if the unoccupied set point are blocking the occupied set points run the unnocc. temp down and then set the occ. set points down. Good luck
Posted on Jun 30, 2011
Need a power cord for a Lektro Maid Skillet (Heat Controlled Dial No: 3679)any ideas?
go to any electrical shop or appliance repair shop and ask them
Oct 26, 2016 | Heating & Cooling
I need a new power cord for my west bend skillet
West Bend Electric Skillet ' eBay
eBayFind great deals on eBay for West Bend Electric Skillet in Electric Skillets. Shop with ... NEW West Bend WB1 Heat Control Sensa-Temp Power Cord Plug Probe ...
Nov 28, 2015 | West Bend Kitchen Appliances - Others
I have a precise heat oil skillet and need to get in touch with the company about warranty . I need a phone number for customer service
I need a replacement temperature control unit for the Precise Heat Electric Skillet, KTES2. Where can I get this?
Mar 09, 2010 | Precise Heat Kitchen Appliances - Others
Heating element won't heat. Control light comes
your element is shorted
since the elemen t is welded and fitted to the bottom of the pan it can be fixed but should not be
my advise get a new one
rival will just say it has water damage
Oct 08, 2009 | Rival S16RB Electric Skillet
Electric plug turns off
That is your thermostat going on and off. There is nothing wrong with your skillet. When it reaches the desired temp, the light goes off. When the temp drops, it will come back on.
Jun 29, 2008 | Rival S12T Electric Skillet
Kitchen Appliances - Others Logo
47 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
