Question about Optics
Looking for firing pin for a H&H 22 rifle Bolt action
  • 88 Answers
SOURCE: Benjamin Air Rifle Model 342 not building pump pressure
Springs tend to loose their performance after a few years is air rifles. Check also the seal/o rings on the piston rod and the blow hole. I found waxing it with Vaseline makes it last longer and seals more.
Posted on Aug 29, 2009
Blue Dog
  • 75 Answers
SOURCE: looking for the age of a Remmington model 121
These rifles were made between 1936 and 1954. There is more detailed information about them on the Remington website.
Posted on Oct 17, 2009
  • 35 Answers
Cant give you an Exact but I can give you the Manufacture Years:
Manufactured from 1936-1954
Posted on Oct 18, 2009
  • 302 Answers
SOURCE: I have a Savage bolt action Model 110 .270 Caliber
go to and go to the mount/ring search wizard for the right info. hope this helps you
Posted on Oct 24, 2009
  • 2100 Answers
SOURCE: I have a mossberg mod 352 KB with a broken firing
Go to online, they have schematics for every gun ever made and parts to boot. They sell to the public, certain items of course. Check them out.
Posted on May 30, 2010
Contact a local gunsmith for this. This site doesn't sell parts or have anyway to find them.
Feb 16, 2017 | The Optics
I recently bought a Savage 22 model 64 rifle. It fires great except for having to use the bolt everytime to eject and load today. Today was the first time I fired it. What could cause this problem?
Make sure the action is clean and lightly lubricated. check that the ejector isn't broken. Try a different make of ammunition. If none of that works, take it to a gunsmith.
You are using Long Rifle ammunition (.22LR)? It has more recoil to operate the mechanism.
Feb 20, 2016 | Optics
Trigger problem on my Yugoslavian SKS rifle. when the bolt and carrier are locked in the firing position it pushes down the pin on the trigger group and the hammer will not fire. If you pull the bolt...
I'm having trouble visualizing which pin (firing pin???) you're talking about. How sure are you that the rifle has been reassembled correctly? Could you post a picture so we can see how it's assembled? One shot (no pun) of the assembled trigger group would be good, then another shot of the bolt & carrier.
Aug 07, 2014 | Optics
My 597 22 rifle only every other round will fired. How do I fix it?
Couple of things could be happening:
dirty firing pin channel
Bad lot of ammunition.
Light/broken hammer spring.
Clean it thoroughly and shoot it again.
Mar 19, 2014 | Remington Model 597 .22 Long Rifle 16.5...
22 semi auto rifle jamming
Often with semi-automatic rim fire rifles, the most common cause of jams/failures to feed are related to improper cleaning. Most of these low-powered rifles utilize a blowback action to fire, and thus require a clean breech and chamber to provide proper obturation of the cartridge. Give your rifle a thorough cleaning, including a detail strip and clean. If you are experiencing other types of stoppages such as failures to extract or failure to feed, you may be experiencing a mechanical issue such as a worn extractor claw, or a weak magazine follower spring.
Feb 28, 2014 | Marlin Model 60 .22 Cal Rifle
Firing pin not hitting primer in center of round, several miss fires.
A .22 long rifle is a RIMFIRE round. The firing pin should hit the cartridge on the rim. If the firing pin energy is too light, it will not fire. Cleaning the bolt/firing pin slot should help.
Aug 13, 2013 | Savage Arms Model 64 Package .22 Long...
Bolt stuck in closed position after cleaning XL7 30 06
If you had the bolt sleeve or cocking piece out of alignment, it will jam. You should call 1-800-544-8892
to see what they have to say about it
Feb 22, 2013 | Marlin Model XL7 Rifle XLTL3006, 30-06...
I have a mossberg 4x4 rifle bolt on action 30 06 i have alot of misfire catridges all of them they have that they get hit from the pin ,but i guess not hard enough to fire
I would suggest that the firing pin channel needs to be cleaned. There may be a bit of crud or rust that is keeping the firing pin from applying a consistent strike to the primer. There may also be a burr that needs to be cleaned up.
Mar 20, 2011 | Mossberg Sport & Outdoor - Others
Where is the serial number located on a remington model 37 rangemaster, cal,22 rifle?
693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
Ending: 12300 Grades Offered: Model 37 Rangemaster
37 Target
37AS Variations: None
Dec 11, 2009 | Remington Sport & Outdoor - Others
Winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Apr 05, 2009 | Sport & Outdoor - Others
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
