Question about Vacuums
Model EL 1061 stic vac keeps shutting it's self off. I have taken it apart and cleaned it inside (it was vert dirty). It still does the same thing
4 Suggested Answers
  • 125 Answers
SOURCE: beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Posted on Mar 09, 2009
Vac Belts
  • 701 Answers
SOURCE: the water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Posted on Dec 03, 2009
  • 519 Answers
SOURCE: where can I buy a ktec model ka12d150020033u charger for an eureka stic vac 2in1 easyclean
Try eBay
Posted on Jan 20, 2015
Turns on and then shuts off
there is a self reseting thermal cut out sensing motor temperature. The motor is overheating due to lack of ventilation, probably obstructed by dust and stuff. Vac needs to be taken apart and cleaned to make sure.
Apr 24, 2015 | Bosch 3931B-SPB Airsweep 6.6 Gallon...
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover steam vac spin scrub won't suction the water up.
I fixed my problem by repositioning the tunnel that is on the front of the pick-up tank. It had moved out of position and not allowing a tight seal. It is the white plastic piece that slides a little bit. Good luck.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Beater bar on singer central vac stops beating
Mar 07, 2009 | Singer Vacuums
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Hoover F5809
That cover is the called the fan cover and is usually pressed on. Tapping on the edge with a flat blade, you may be able to get it off and hope you don't bend it up, you will to put it back on tight enough so it will stay in place. Another thing to take apart and clean is the turbine, this is what will turn the brush block. Learning TV repair isn't easy, I used to do that for about 30 years along with microwave and other electronics.
May 17, 2008 | Vacuums
Hoover steamscrubber
I had the same problem. Fixed it by taking the machine apart and lubricating the bearing inside the turo tunnell. It's a pain, but not impossible if I could do you can. You must start by taking off the cover. Don't forget the scvrews on the front by the water vacuum. I used WD-49 and white grease so far so good. The turbo tunnel will come out by itself.
Dec 30, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
