Question about Ryobi Garden
How do I remove the air cleaner cover on Ryobi RBC254FSDSN 25cc line /brush cutter,has a plastic retainer in the center that just keeps turning and not coming loose
SOURCE: ryobi lawn hornet wont start....continually
Hi Tamcoff - If its the same model as mine (and you can't always rely on the Parts Cattledog!!):
- to remove the bell housing; twist off the spring and using a T20 torx screwdriver unscrew the retaining screw in the centre of the housing (normal RH thread)
- place a large screwdriver in the slots of the cover to jam the impeller and using a copper drift (or similar) and hammer, tap sharply the in one of the clutch recesses (one of mine hasd 'OUT' embossed in it) unscrew the clutch from the drive shaft (normal RH thread)
Cheers,
Bob
Posted on Dec 08, 2008
SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Posted on Mar 17, 2009
  • 272 Answers
SOURCE: the plastic protection cover over the cutter is broken replacement required
Small Appliance.com has the part you need.
http://www.smallappliance.com/product.asp?cur=USD&cam=drg_247-10398&sid=18954&gid=19013&mid=20&pid=3472&prdCls=P&shopBy=Brand
Posted on May 22, 2009
  • 148 Answers
SOURCE: Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Posted on Jul 16, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
Spark Plug Cover keeps popping off Spark plug when under load causing trimmer to cut out on my RYOBI RBC254FSDSN
Sounds like your spark plug boot has gotten soaked with oil or some other contaminent. Replace spark plug boot with a new one.
Jan 03, 2015 | Ryobi Garden
I have a ryobi x 430 string trimmer. The timing belt came off as mentioned in other postings and I put it back on according to online tips. It ran well for a while. Now, it is hard to start, but it...
It is possible that the timing gear jumped a tooth. Take off valve cover and check to make sure timing marks line up. Other than that check other things like carb adjustment, good gas, air filter and other general tune up things.
Aug 27, 2013 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi bc30 idle and run probloms; plastic ends on ajustment screws on carb keep you from ajusting carb. how can you ajust. can start with chock but will not run with chock off.
mmarote, this is what I did to solve that problem....remove carb...take a hacksaw or dremel tool and cut or grind slots straight across the centers of both screws deep enough to get a thin bladed screwdriver in the slots....turn to adjust....et voila....
Jun 25, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Arbor stuck on gear head/bc26
I have the same problem. Any solution?
Apr 20, 2010 | Ryobi Garden
The starter housing assembly of my ryobi brush cutter is damaged
If your somewhat mechanically inclined, you should be able to. I would need your model # to quote you a price for this part. We are a warranty service center for Ryobi, Ridgid, milwaukee, Campbell hausfeld, etc. Email your model # to desertairrepair@aol.com. I'll send you the schematic for your trimmer.
Feb 02, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi ss 30 will start in choke but will not stay running
I hope this will fix your problem.
Look on your carbrator and by the idle adjustment screw there is two screws ( The screws may have plastic or metal caps on them) Just use a super small pair of needle nose plyers on them. Turn the screw next to the engine 1/2 turn counterclock wise. check to see in motor will run better.
metordgreat@yahoo.com
Jun 24, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi 25cc plt srimmer starts then dies , wont run
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 21, 2009 | Ryobi Garden
The fuel line leaks coming out of the plastic fuel tank on my Ryobi Brush Trimmer (990R I think). I am replacing the old plastic fuel lines into the tank but noticed that they are a little loose too. Any...
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
May 15, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
65 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
