Question about Whirlpool GC5THEXNS Stainless Steel Side by Side Refrigerator
Whirlpool Side by Side Freezer - Ice Build Up in Drain
We have the same problem, same exact model, only a few years old - ice build up at the bottom of my freezer side of my Whirlpool freezer is blocking the drain. The freezer has ice build up all over but the refrigerator side is too warm due to the fact that the vents to the fridge are blocked with ice. The repair man said to let it thaw - we are in the process of this now. I am wondering why the ice would build up in the first place? Seems as if this is a common problem. We can hear water draining into the pan...
  • 374 Answers
common problem,several factors can be check,check your thermostat setting it maybe too low or you have defective thermostat,if you have good thermostat otherwise the refrigerant charge is to low there could be leak on tube,check your amper rating using clamp ammeter if you got low amper rating recharge freon,but why has low refrigerant there might be leak,repair the leak,before you recharge.hope this solve your problem have a nice day
Posted on Jul 21, 2009
  • Whirlpool Master
  • 1,606 Answers
After the drain thaws , ( I use about a 4 inch aluminum fence tie or if need longer , aluminum wire with no insulation ,) insert it into the drain hole as far as it will go with no force , and wrap the top end about 1 turn around the calrod defrost heater , This transfers heat to the hole so the ice will not freeze up the hole . Before doing this step , use a hose and blow into the drain to possible clear out any debris which could have accumulated in the drain trap .
  • 42 Answers
the reason for this ice build-up is that your auto defrost heater didn’t come on. this makes the freezer side cold and the refrigerator side warm.
try keeping a pot of hot water in the freezer to completely defrost the freezer.
make sure that the gasket doesn't have any blocks.
this should solve your problem.
cheers.
WHY IS MY SIDE BY SIDE WHIRLPOOL leaking water onto floor?
normally caused by a clogged drain in back of freezer . check to see if you have ice build up on bottom of freezer..... gently chip away ice in freezer and turkey baste hot water into drain hole until water flows freely
Aug 27, 2014 | Whirlpool Refrigerators
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice build up every few weeks
Change the defrost heater inside the freezer. Located behind panel inside the freezer at the bottom.
Jul 09, 2009 | Refrigerators
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
GE Side by side runs constantly.
EASY FIX!!! The drain is clogged up. All you have to do is take the back wall to the freezer off (lower section in freezer) And you will see another layer of frozen ice at the bottom (behind back wall). Get you a hair dryer and start melting. After a few minutes u will start to see a drain whole(size of a nickle in middle) concentrate you efforts on the drain hole. Now get some wire or something and stick down in hole, then pull out over and over till finally it drains all the build up water around the hole! GOODLUCK!!!
Dec 17, 2007 | GE GSH25JFR Side by Side Refrigerator
Whirlpool GC5THEXNS Stainless Steel Side by Side Refrigerator Logo
840 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
