Question about Sharp Office Equipment & Supplies
Sharp AR5516 PAPER JAM I get paper jam error, Once the paper passes halfway through the fuser unit. I have adjusted all that can be adjusted. I have also cleared paper part but not working. Help
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Posted on Jan 06, 2009
rezazadeh
  • 328 Answers
SOURCE: SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
Posted on May 29, 2010
  • 97 Answers
SOURCE: I have Xerox Phaser that had a paper jam in the
The fuser exit sensor arm is a delicate piece of black plastic. It's possible you damaged it removing the paper jam. Remove the fuser and see if the sensor arm is still intact. It's in the middle of the machine.
There's more detail about the 7300 here:
http://michelsplace
Posted on Mar 02, 2011
  • 217 Answers
SOURCE: Paper jam in fuser unit
Sure you can open the fuser. But if the problem returns you better put in an other fuser
Posted on Nov 10, 2011
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
We can not clear the paper jam error. We have cleared the paper jam, turned the unit on and off, unplugged the unit, moved all the rollers, can not see any pieces of paper that are still in the misfeed but...
This copier has 4 sensor
1. paper sensor
It is called paper sensor its installed paper tray
2.Drawer sensor
3. Drive sensor its installed middle position
4. Exit sensor it is in fuser unite.
May be any sensor displace or broken.So you should check it.
Good luck.
Feb 16, 2011 | Sharp AL 1631 Copier
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
May 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
Paper jam light on
the censor that detect presence of paper in the printer has stopped working. check it if you can or get it repaired from local sevice centre......
Sep 29, 2009 | Sharp AL-1217 Copier
Printer problem
even a very small piece of paper (A small piece torn off a jammed sheet) can cause the sensor arm to stick in place giving a false paper jam. Double check the entire paper path (what is visible) using a flashlight.
Also, check for broken "flag" sensors. Basically a flag sensor is a small piece of plastic that is pushed out of the way when the paper is traveling through the unit. If one of these flags is broken it may display a paper jam error as well (The flag after paper travels through will drop back into the paper path.) If this is broken it will not trigger the sensor and thus the error condition exists..
Most likely you have a small piece of paper stuck inside the paper path somewhere.
Do not, I repeat do not use any sharp or pointed metal objects to remove any small paper from within the fuser unit, the fuser covers are very delicate and such poking and prodding will likely damage the fuser covers, causing bad print quality or drastically decrease the fuser life (a small tear will quickly render the fuser useless).
Hope this helps!
Aug 31, 2009 | HP Office Equipment & Supplies
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Paper Jam Message
Where is it saying the paper jam is located? Do you have a service code? It sounds as if either a paper pass switch is stuck in the down position (meaning it thinks there's a piece of paper there), or you may have a sheet of paper stuck in the fuser or behind a guide plate. Check on these and let me know!
Apr 10, 2007 | Sharp AL-1655CS Laser Printer
29 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
