Question about Fisher Dryers
DEGX2 Fisher Paykel dryer power button pushed but no response checked power supply both places what could be wrong I just used it a few days ago and now nothing.
    New Friend:
  • 7 Answers
Clean the filters. Reset the hi temp klickson
Posted on Dec 18, 2016
Fisher paykel troubleshooting
place your hands on the drum and push it backwards . the door will open when it comes around .
Jul 19, 2014 | Fisher and Paykel DEGX2 Dryer
Service Manual for DEGX2
Get the model # and go to Fisher Paykel website for info or to order the service model. Also you can enter your model and it will show you a breakdown on parts.
Mar 17, 2013 | Fisher and Paykel DEGX2 Dryer
My Fisher and Paykel Model Degx2 The drum is stick it will not open. Can someone help me please
see this and fix it. God bless you
If your electric dryers control is locked try the following. First make sure there is not a seperate control lock button if there is press one time to unlock. Next locate the end of cycle button and press and hold for 3 seconds. If this does not clear it press and hold for 15 seconds. Still not cleared shut off breaker for 5 minutes if this does not correct the problem replace the main control.
Sep 28, 2012 | Fisher and Paykel DEGX2 Dryer
Dryer not hot have to push manual reset. does not work for long
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Fisher and Paykel DEGX2 Dryer
My Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND LONGER TO DRY CLOTHES AND THEN JUST STOP DRYING-DOESN'T GET WARM. THE HEATING ELEMENT WAS REPLACED ABOUT 7 MONTHS AGO. IS THERE A RESET BUTTON IN THE...
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Nov 13, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Won't heat - otherwise acts normally....
You could check for obstructed vent of excessive lint.
I have an old dryer manual for fisher/paykel
for the x1, how different can they be? LOL
Oct 22, 2009 | Fisher and Paykel DEGX2 Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Dryer-DEGX2
OK I had this issue as well. I ended up opeing up the dryer and cleaning all the connections. After that it came right back up. It would start with the displaying going haywire. Easy fix and saves you a tech coming out.
1. Take off lid
2. open up the buttons with 2 screws in back
3. Pull electric wire connection and blow out.
4. unscrew 2 screws top front. Covered by rubber stops
5. Lift Lid and blow out. Sensor on the left top.
Worked for me.
Oct 26, 2008 | Fisher and Paykel DEGX2 Dryer
Dryers Logo
Top Fisher Dryers Experts
Tim Whalen
paul
paul
William Goodman
William Goodman
Level 1 Expert
Are you a Fisher Dryer Expert? Answer questions, earn points and help others
