Question about Seiko Watches
Hi, the buttons B & C are jammed on my Seiko 7T92 wrist watch. Is there a lubricant or substance I can use without effecting the watch to free these buttons?
  • Seiko Master
  • 19,004 Answers
With Seiko, the best thing is to send it to Seiko for service. They will clean it and replace all the gaskets on the buttons, and pressure test it.
If you want to try yourself. It is waterproof, yes? Soak for a couple of hours in warm soapy water. Lift out, dry, and try the buttons. If they are now free, spray with Jigaloo, which is a dry silicone spray and work into the buttons.
Posted on Dec 18, 2016
Testimonial: "Great, thank you I will remove the centre and soak as suggested."
  • 2 more comments
  • Andrew Taylor
    Andrew Taylor Dec 18, 2016
    Remove the centre? Aren't they side buttons like mine, 2 either side and a winder on the right side.
  • Karl Wennig
    Karl Wennig Dec 20, 2016
    No, 2 buttons on winder side and to soak in warm water I would assume the mechanics of the watch would need to be removed so that the case can then be submerged and soak for a while hopefully freeing the buttons. The the centre is easy enough to remove. Unlike most winder shafts where a pressing down to release the winder shaft is required in this model the retaining lever just needs to be held where it is so it doesn't stop the winder from being removed.
    Cheers.
  • Andrew Taylor
    Andrew Taylor Dec 20, 2016
    Mine is waterproof to 50 metres, and the back screws on. If you can remove the works, then great, do it, as the warm water can penetrate from both sides.
  • Karl Wennig
    Karl Wennig Dec 21, 2016
    Yep, mine is water resistant with pop off back.
    But the trick was to learn how to remove the crown and shaft:-)
    Thanks Andrew.
Hi, got a seiko 7T92, the stopwatch second hand, can this be made to work as a second hand or is it only for the stopwatch function, it's annoying that it's still all the time!
If you can have both clocks running at same time, yes but they'll be on different screens. you just have to go back and forth between screens.
Apr 02, 2016 | Seiko Watches
Need battery # Seiko 7N43 9070
You can purchase your battery from amazon, take a look here: Amazon com SR920SW battery (SR920SW battery is what you need). I hope this was helpful. Cheers
Nov 18, 2012 | Seiko SGF204 Wrist Watch
The date on my Seiko SWZ054 watch has the correct date but wrong day. How do I fix?
Welcome to Fixya. Can you please provide the caliber number of your Seiko SWZ054 Wrist Watch for me to be able to check the manual and give you the information on how you can update the day on it?
Thank you for using Fixya,
seancarlisle
May 13, 2011 | Seiko SWZ054 Wrist Watch
My Seiko SNA548 Coutura watch slows down. I replaced the battery and it still slows down especially during cold weather. Could it be the the lubricants in the watch are causing the problem?
isnt that model kinetic? if so, if you arent doing about four minutes of aerobic activity in the course of the day, it will go dead. if for some reason you cant (or dont) get much activity, take the ****** off and shake it for a while
Dec 30, 2010 | Seiko Coutura SNA548 Wrist Watch
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Oct 17, 2010 | Seiko SKA192 Wrist Watch
Second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Dec 06, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
How to set the alarm on a seiko presage chonograph?
Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
Resetting the 'day'
Your Seiko has two pulls,first pull for DAY / DATE,and the second pull for the hour and minute.Just do the first pull then wind it clockwise for DAY and the counter clockwise for DATE.Feel free to ask whatever the result...
Hope this may help;
Regards,
VOTIT
Sep 03, 2008 | Seiko 0512037FA Wrist Watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Watches Logo
29 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
