Fault light are blinking
The intake and drain light are blinking and the machine does'nt work
  • 6,784 Answers
HI, there may be a clog in the drainage assembly. check all corresponding hoses and pump as well. if the hoses are clear of debris, this may confirm a pump malfunction. replace the pump in this case.
Also, check the inlet water valve assembly as well for non responding valves. replace the valve if needed.
Posted on Jul 21, 2009
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
W1213 Touchtronics intake and drain light is blinking
Foam has probably got into the logic board, and a new board is probably needed. Sorry !
Feb 02, 2018 | Miele Touchtronic W1213 Front Load Washer
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
How to fix a Miele W1213 Touchtronics washer when the intake and drain light is blinking? power for drain motor is only 20V drain motor not working,but I am tested with 220V end is o.k.
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Jul 06, 2008 | Miele Novotronic Premier 500 Front Load...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
