Question about Tools & Hardware - Others
Motor tecumseh rpm go up and down all the time
How do correct RPM surge on a LH 195 Tecumseh engine
Hi you're governor gears inside the motor could b the problem ...good luck
Aug 11, 2015 | Tecumseh Garden
Victa mustang tecumseh just had service done please explain what this means:checked max rpm reset rpm to oem limitsthanks
A gasoline engine is made to rev up only so fast. If it revs or speeds up too fast it will blow up. Each engine has a rpm limit. There are springs and settings on the carb that controls this and you should not have to worry about it if some one has checked it out. They are just making sure your engine will not rev up too high.
Mar 24, 2014 | Tecumseh Garden
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
I have a 10 hp Tecumseh Gold Series Snow Bolwer with 6 forward speeds and 2 reverse and I'm trying to find a owners manual for it, thanks.
If you locate the model number of your motor you should be able to download an Operator's Manual for the motor form this site:
http://www.tecumsehpower.com/
Is this an actual Tecumseh brand snow blower or another brand with a Tecumseh motor installed?
Jan 28, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
We have Tecumseh TSH 359/22272/81 motor on a Stiga snowblower. It did start and work but blew most of the oil out. Now it wont start. Where can I find new motor or parts, motor seems to have two axels...
Hi and welcome to FixYa. I am Kelly.
The fact that the engine blew out most of the oil during normal operation is an indication that there is a problem with the crankcase breather. You can usually resolve this by removing the breather from the side of the engine at the base of the valves and cleaning it with engine degreaser and carb cleaner. What I think happened was there was a bit of condensation in your breather and it FROZE in the closed position forcing the crank case to over-pressurize and porting the oil into the breather.
If by chance you over-serviced the engine oil before the last operation it will present the symptom you describe. Also if you tipped the unit more than 30 degrees.
It most likely will not start now from an oil fouled plug.
You can use this manual for locating "How to" repair your engine:
http://www.cpdonline.com/692509.pdf
Here is what the service manual says on page 82.
BREATHER PASSING OIL
1. Check the oil level, make sure the engine is not overfilled. Also verify that the viscosity rating on the container of
the oil being used is to specification.
2. Check the angle of operation. Avoid prolonged use at a severe angle.
3. Check the engine R.P.M. setting for excessive R.P.M. using a vibratach or other tachometer and compare it to the
R.P.M. settings found on microfiche card # 30 according to the engine model and specification number. Adjust the
high and low R.P.M. as necessary.
4. Check for leaking or damaged gaskets, seals, or "O"-rings. External leaks may not be evident; however, the leak
may prevent the engine from achieving a partial crankcase vacuum.
5. Check the breather for damage, dirty condition, or improper installation. The oil return hole(s) must face down.
6. Check the engine compression using a compression tester. If the engine has weak compression, determine the
cause of weak compression: worn rings, leaking head gasket, or leaking valves. Follow the compression tester's
procedure.
I can help more... the engine number you passed did not cross.
Thanks for choosing FixYa,
Kelly
Jan 25, 2011 | Tecumseh Snowblower Snow Blower Starter...
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Is there any way to quiet down my Tecumseh Craft. Gen?
longer exhaust pipe from motor and better muffler. Go with a larger pipe too to allow for better engine performance. You can get a tractor muffler from Tractor Supply that meets your needs.
Oct 07, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I need to know how to adjust the carbureator on an tecumseh lawn mower model number 143.954500
If it has a float type carb, open it 1.5 turns. If it has a diaphram open it one turn. If it has a Walbro carb, there is no adjustment. Once you get the engine started you may adjust the carb to fine tune. Open until it begins to lose RPM's then close until it starts to lose RPM's. Return to a point between the two. Good luck...Lee
Sep 05, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
