Question about Yamaha Audio Players & Recorders
Connecting Yamaha DSPA2070 To BSR AQL 300 equalizer.
Have been doing this a bit and seemed simple enough, but all I'm getting is power and no signal read. Am using Y splitters with multiple devices on amplifier main in; left and right from main in to EQ line out + left and right from EQ line in to receiver main out. Unit powers up and I get a hissing; no response to sliders +12 to -12 in gain or loss. Sliders light but spectrum analyzer displays nothing.
3 Suggested Answers
  • 133 Answers
SOURCE: i have an old integrated amplifier and an old BSR
Hook the signal source to the equalizer input and the equalizer output signal to one of the signal inputs on your amp. This is one way, but this way only one signal source will go through the equalizer (unless it has several signal inputs and a source selector switch).
The other way (inserting the equalizer between the preamp and the main amp) is:
If your amp has RCA connectors on the back named "preamp out" (or similar) and "power amp in" (or similar) that have slugs connecting them, remove the slugs, hook the "preamp out" signals from the amplifier unit to the signal inputs on the equalizer and outputs from the equalizer to the "power amp in" inputs on the amplifier.
Basically, what you do is that you insert the equalizer between the preamplifier section and the power amp section of the integrated amplifier so that you can still select the signal source without having to switch any signal cables (however, i can't say if your amp has got this type of "slug" connection feature between the preamp and the power amp on the rear panel, so i'm not sure which way you'll have to hook it up).
Hope you can make it work the way you want.
regards
Triarcuate
Posted on Oct 01, 2009
  • 43 Answers
SOURCE: connect stereo amplifier to powered sub
You must use a sub woofer using speaker wire inputs and outputs. You cut the two wires going to your speaker, connect it to sub in and then hook the wires attached to your speaker to sub out connectors. The type of sub you have only connects to pre amps with a sub out RCA connector like the one on your sub woofer. Buy a new preamp or a sub using speaker wire in/outs if you wish to keep your existing preamp without a sub output RCA connector.
Posted on Apr 06, 2013
How do I hook a bsr eq-1 equalizer to a Yamaha av receiver rxv573
Seems like it should be , audio out to the eq. Then out of the eq to your sound source, ( speakers )
Apr 22, 2015 | Yamaha Audio Players & Recorders
My turn signals on my 1982 yamaha xj650 stay on after I installed led turn signals
Hi, Anonymous you need a load equalizer for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Kuryakyn Load Equalizer for Run Turn Brake for Yamaha Each
on 82 xj650
Yamaha XJ750 Owners Workshop Manual
OEM parts for Yamaha
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
May 10, 2014 | 1982 Yamaha XJ 650
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
I HAVE A BSR 3000 EQ, A TECHNICS POWER AMP SE-9021K,AND A TECHNICS SU-9011K PRE AMP HOW DO I HOOK IT ALL UP?
Very easy.
SOURCE > PRE-AMP > EQUALIZER > POWER AMP.
Not sure why you want to do it, though. Your pre-amp already has an abundance of sophisticated tone controls and filters.
If I might venture a guess, you are trying to correct some serious deficit in your speakers or in your source. If you need sophisticated tone controls, filters, AND an equalizer, you need to ask yourself why ... and fix that problem.
Oct 12, 2012 | Audio Players & Recorders
1983 Yamaha maxim 1100 turn signals not working
Hi, Melnykracing before testing any electrical component in the Light Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries, also before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with one or all LED lights you are going to need a load equalizer.
If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion.
If all four turn signals flash at the same time like hazard lights even though you only pressed one turn signal button then you have a LED light in the circuit and need a load equalizer that can be purchased from any motorcycle parts supplier.
If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function.
If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction.
If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, the harness connector is usually located under the seat on the front of the rear fender then keep tracing the wiring look for obvious harness damage caused by the rear tire.
If you still can't find the malfunction backtrack from the rear fender wiring harness connector.
If one side does not work you could have a faulty turn signal switch or module check for continuity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Message Board Motorcycle USA
YAMAHA XJ LED SIGNAL FLASHER RELAY FIX
Yamaha XJ1100J Service Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jun 05, 2011 | Yamaha Motorcycles
Im useing the Yamaha MG24/14FX mixer, and ATM Kustom KSE215 speakers, seems like there isint enough power Granted these speakers are 300 or so watts, had a few problems with these speakers with my old...
The MG24/14FX is a mixer only, with no amplifier built-in. It can't drive speakers directly. You'll need powered speakers or separate amps and speakers.
May 16, 2011 | Music
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Apr 15, 2010 | Denon Audio Players & Recorders
Eq to receiver
Connect through the tape monitor jacks and if a tape deck is used connect it to the eq! Check your owners manual if you still have it or download one.
Apr 14, 2010 | Yamaha EQ-70 Home Equalizer
I have an old integrated amplifier and an old BSR EQ-3000 stereo frequency equalizer. i just bought a used bose 901 speaker set. how do i hook-up the bose 901 equalizer in this system?
regards
Triarcuate
Sep 30, 2009 | Bose 901 VI Main / Stereo Speaker
My yamaha htr 3750 said check sp wires then turned off so i unplugged all the wires then tried to turn it on but it turned back off after 5 seconds
Your Yamaha is going into protection model.
This mostly happens when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
If everything else seems all right and still your receiver shut down then it possible that
1).there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. I could guide you a bit. If not, then a local service center will change the local labor rate.
2). Some transistors have blown on the output power board:
This will require little bit of more electronic knowledge.
I suggest if your set is still under warranty, then please take it to Yamaha.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Thanks for using FixYa!
Mar 12, 2009 | Yamaha HTR-5730 Receiver
51 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
