Question about Empire Heating & Cooling
Empire rh 35-6, where does the ignitor wire hook up
I have a empire heater model rh 50cb-2 that has flakes of soot in and around heater, what would cause it
Soot is from bad combustion yellow flame lack of air blocked burner . Needs a service .
Jan 22, 2018 | Empire Heating & Cooling
I have an Empire RH-65B-6 Natural Gas heater. It is 4 years old, and the flame is quite high.. enough to where it chars the ceramic log on one end and leaves "soot" on the viewing windor. What shoul
I'M GEUSSING THE FLAME IS QUITE YELLOW IN COLOR CORRECT? IF SO THE AIR SHUTTER WILL NEED ADJUSTMENT ON THE END OF YOU BURNER TUBE ASSEMBLY. HOPE THIS HELPS
Dec 27, 2012 | Empire Heating & Cooling
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
Empire Hearter (old unit) Model # DU 215-7SG Pilot light goes on and stay on but the main burner will not ignite.
I notice that I have the same problem and the wire coming out of the frame on the outside opposite where the thermocouple attaches to the frame on the inside goes nowhere. Shouldn't that wire connecting to something? If so, exactly where is the point of attachement of that wire? It should control the opening of the main gas value somehow.
Richard
Nov 02, 2010 | Empire DV-35 Heater
Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Sep 04, 2009 | Empire DV-35 Heater
I have a travel trailer with a roof top a/c colman mach111 and I hooked up a thermostate digital. The heat works but cant get a/c to come on. the termanials on hunter thermostate are G W Y RC RH
OK, the wiring that you should have in your RV is as follows: Red White Blue Yellow Green Gray.
This Thermostat will not work on this Air conditioner because the tstat you are installing is a 24V thermostat. The connections are as follows G = Fan, W = White, Y = Cooling, RC = 24V Cool, RH = 24V. The only thing that I can think to do is hook it up like so.
On the G Terminal, Hook up the Green wire from the wall. On W, hook up the White wire, Y, hook up the yellow wire. RC = run a jumper from the RH terminal, RH = hook up the red wire. If this doesn't work then you will have to go back with the coleman thermostat.
Jul 03, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
