Question about KitchenAid Food Mixers
The planetary housing of my Kitchen Artisan mixer moves up and down. I can move in with my hand and it moves up and down occasionally when mixing. This just started.
Is there a piece that holds this housing in place that needs to be tighted or does the whole piece need to be replaced?
  • KitchenAid Master
  • 1,297 Answers
Properly having a look to find the cause is going to involve removing the planetary (remove chrome drip ring and knock out the pin) and then removing the back cover. Remove the white and the black wires from the speed control and take the return spring off the bottom of it. Undo the 9 screws holding the gear cases together and separate the 2 halves. You will now be able to inspect the shaft, spacing washer pins and gears on the planetary driving shaft. Normally they have a bit if movement up and down in the planetary (when it is fully assembled) I've never found a fault within the gearbox to cause it or if I have it's been through someone pulling it apart and not assembling it correctly. When I do them I add an extra fibre washer on the outside between the planetary and gearbox housing, there should already be one there, I add another of suitable thickness to remove play but not make it tight.
Posted on Dec 20, 2016
I successfully got thevpaddle off, but the spring that allows you to put the attachments on wont push up. How do I get it to do so?
I'm puzzled too. The many KitchenAid mixers which I have worked on have had other problems, but not this one. The link below will take you to a copy of the mixer Service Manual. While it does not specifically mention the Artisan, that model (as far as servicing goes, is the same).
Jan 14, 2015 | KitchenAid KSM150PS Artisan Series Stand...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Squeak while mixing.
That sounds like the accessory drive is binding in the bush in the front housing. Don't use it and think seriously about getting it to a Kitchen Aid service agent. No good will come of forcing the issue. If you never use any accessories in that front drive you could consider asking them to remove the gear and put it back together again without it. If you force it to continue eventually the fuse gear will fail and you could even wreck the gear that drives the planetary. The accessory gear will need to be replaced and if the bush is damaged enough the top housing will need to be replaced as the bush is not available separately.
Mar 03, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Service advise for kenwood a700d
The planetary gear housing is filled with grease. Seeing oil come out would indicate that grease has started to or has completely broken down. Take the planetary apart (One nut and a clip), clean out the old grease and liberally repack with a food grade grease something like PTFE Super Lube .
Jul 15, 2013 | Kenwood KM300 Chef Stand Mixer
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
A gasket type rubber ring is coming out of the assembly that the beater is attached to? it will not stay in place. where does it go? in the PLANETARY UNIT?
Get a copy of the Repair Part List for your model at
Download a Copy of the Kitchenaid Service manual.
Somehow the O-Ring is coming off of the Vertical Center Shaft (11)
That rubber ring prevents Oil from the transmission gears dripping down
to the Planetary into your mix.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Download the following Kitchenaid Service Manual:
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
We moved and the mixer fell on it side and oil came out of it. Its a Kitchen aid Artisan Model rrk150ww
nydadinga - Sorry to hear about your fallen mixer. This is not a tragedy, and after cleaning up the grease with soap and water, it should operate normally. Your KA mixer has internal transmission and planetary gears which convert the electric motor's rotation into the mixer's rotation. The internal gears are factory packed with enough grease to last a 'lifetime' (whatever that means), and over the course of your move the shifted mixer leaked the grease inside the transmission housing. You did not mention where the 'oil' was found. Hopefully it was not exuding 'oil' from the brush cover caps located on opposite sides of the body, but coming from the planetary (the part that turns with the blades under the body). I also don't know how old/how used your mixer is. The older the mixer, the more used it is, the more fluid the gear grease, and tend to seep from cracks and gaskets that aren't tight. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. You can download it from KA customer care. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number and select the Part List file that is listed. I hope this helps! Howard, Burke, VA
Nov 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
75 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
