Question about Masterbuilt Kitchen Appliances - Others
Masterbuilt turkey fryer temp light blinking is the unit heating up?
mvbeads
  • 34 Answers
SOURCE: I lost my manual for my Masterbuilt 20010406 Deep
The manual for Masterbuilt 20010406 Deep Fryer is available online for easy download and print:
http://masterbuilt.com/pdf/manuals/20010406%20&%2020010306%20Digital%20ETFV.pdf
I hope this helps.
Posted on Nov 19, 2009
proartya8765
  • 581 Answers
SOURCE: The lid for my Masterbuilt 20010406 Electric
contact the manufactuer online. Nearly all companies sell parts for their appliances.
Posted on Nov 22, 2009
SOURCE: missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Posted on Nov 26, 2009
SOURCE: I have a MasterBuilt 28qt stainless Turkey Fryer.
I've got the same problem and it causes the safety switch on the heating element not to compress thus it want heat. I contacted Masterbuilt and they said due to that model being no longer in production ther were no parts to buy. I'm going to find a way to hold the switch down (maybe with a piece of duct tape) and continue using it as is I guess, I suggest you do the same unless you want to buy the newer model.
Posted on Dec 27, 2010
woobie dog
  • 1273 Answers
SOURCE: my brinkmann turkey fryer doesnt get up to boiling temp
Hi Larry, W/D here. Just got your question so I'm a bit late in getting back to you......
The amount of heat delivered at the burner is dependent on a number of things, and we'll take them in the order of most likely:
1st, The gas tip must be clear. It's possible for critters to build nests in the gas delivery piping that can plug either the gas delivery port or the air side of the mixing venturi; both will give you a reduction in BTU's. Compressed air can be used to blow out the air side of the venturi. The orifice for tha gas can be cleaned with a thin wire, or use a tip cleaner, available at a welding supply store. These are inexpensive.
2nd, The burner proper can become plugged at the ports where the mixed gas/air combusts. These can be cleaned with a small drill bit,sized to the holes, and just passed back and forth to clean them out. Compressed air works well to remove any particles remaining.
3rd, The regulator may be defective. If this is the case, you'll need to replace it as it contains no user serviceable parts.
4th, the in-line regulating valve may be sticking in the partially open position. This is difficult to diagnose, however, and is more of an assumption, after all other causes are eliminated. The cure for this is replacement also.
Hope that this was helpful to you.
Best regards, --W/D--
Posted on Nov 04, 2011
I just looked at the manual online. They don't tell you much do they? Anyway, other appliances that are similar that have the same type of temperature controller usually indicates that the fryer is heating up. Feel any heat?
https://masterbuilt.com/wp-content/uploads/20100809_Butterball-Oil-Free-Electric-Turkey-Roaster_IM.pdf
Nov 16, 2017 | Masterbuilt Kitchen Appliances - Others
Why wont the skin get crispy in the Butterball turkey fryer. We have tried everything.
element isn't getting hot enough. maybe only heating half way. need to replace element and or controller temp inside without food should reach 425 deg.
Nov 02, 2016 | Masterbuilt BUTTERBALL Indoor Electric...
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
I have a Butterball indoor turkey fryer that lost power and the red light went off, is there a reset button on the fryer
There is a thermal cutoff near the heating element just like all appliances that make heat. It's supposed to stop a house fire but makes these appliance companies a lot of money.
Nov 28, 2013 | Masterbuilt Butterball Professional Series...
Fryer is not getting hot and power light is not coming on. What could be the problem?
Usually the problem is related in seating the heating unit correctly in the Control Mounting Bracket. If it isn't put in properly the fryer won't even power on. When you attach the heading unit onto the fryer make sure it is in both slots. Hope this helps.
Aug 08, 2011 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
We used the master built turkey fryer just once after we took turkey out it will not turn back on
That is usually a problem with placing the heating unit into the bracket correctly. If is isn't put in properly the unit won't even power on. You may need to take it off and on several times to get it right.
Jan 02, 2011 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
I have a master built gas frier and just tried to cook a turkey and it didn't work. It took about three hours to come up to 360degrees. Put the turkey in and temp dropped to 225 and stayed there. cooked...
http://www.masterbuilt.com/manuals.aspx?search=M30BV
something is wrong if you followed the manual. I would get in touch with Masterbuilt directly
customerservice@masterbuilt.com
Phone
1.800.489.1581
706.327.5622 (local for Columbus, Georgia)
706-660-8022 (fax)
Address
Masterbuilt Mfg., Inc
1 Masterbuilt Court • Columbus, GA 31907
Nov 27, 2009 | Masterbuilt M30BV Deep Fryer
The part where the heating element attaches to the
I had same problem- they do not make the Control Mounting Bracket anymore - have you had luck finding one?
Nov 20, 2009 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Need manual for master built ditgial turkey fryer turkey fryer
so there are a few different ditigal turkey fryers so go to http://www.masterbuilt.com/manuals.aspx and look for your model. good luck happy cooking
Nov 10, 2009 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Kitchen Appliances - Others Logo
128 people viewed this question
Top Masterbuilt Kitchen Appliances - Others Experts
Richard Lilja
Richard Lilja
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Masterbuilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
