Question about Retail Supplies
L want to check that am registered here at seta
HOW TO REGISTER A COMPANY ON SETA
this is a repair help website......
Aug 11, 2017 | Computers & Internet
Tip
DOOM 3 speed up for ATI & NIVDIA
for  ATI :
***NOTE*** THIS ONLY WORKS FOR ATI CARDS
First, open your doom3\base folder. Doubleclick on the pak000.pk4 file. In the "window can't open this file .. .bla bla" dialog, go on and associate the file with an app like WinRar. With this file open in WinRar, go to the glprogs directory in the file. In there you'll find the shaders. The interaction.vfp file seems to be the main rendering shader. Altering this shader to output a constant color turns most objects into that constant color, except for stuff like computer screens etc.
So doubleclick the interaction.vfp file to open it (you may have to associate the .vfp extension with a text editor like notepad or wordpad first since we're going to edit the file). Scroll down to the fragment shader. You'll find these rows:
Code:
PARAM subOne = { -1, -1, -1, -1 };
PARAM scaleTwo = { 2, 2, 2, 2 };
Add this right below them:
Code:
PARAM specExp = { 16, 0, 0, 0 };
Now scroll down to this:
Code:
# perform a dependent table read for the specular falloff
TEX R1, specular, texture[6], 2D;
Comment out that line by adding a "#" to it, and add another line that will do the same thing with math instead, so it should look like this:
Code:
# TEX R1, specular, texture[6], 2D;
POW R1, specular.x, specExp.x;
Save the file and close your text editor. WinRar will ask if you want to update the file in the archive, select yes. Close WinRar and enjoy about 40% higher performance in Doom3
for NVIDIA:
when I installed the game and attempted to play I got a whopping 2 fps to 4 fps to see what your FPS are put this in consol com_showFPS "1" or set com_showFPS "1" in config file
After I change some in game settings like
600x800 and low quality
Advance setting: I have High Quality Special affect checked yes and Enable Bump maps Yes all the rest are checked no.
After I did these things I am getting average of 21 fps to 35 fps and in high action areas they drop to 15 FPS
so this is what I did to my DoomConfig.
seta image_downSizeLimit "512" CHANGED THIS FROM 256
seta image_downSizeBumpLimit "512" CHANGED THIS FROM 256
Here is actual config just make a back up of your config and copy and paste. Try mine if you have an old Graphix card.
// IvL/FblnaU4w6bO89mN9XIzJKwdEz1acOB3LQ6Vj2NWPrRjcMHDUWwpZzE/zePncK8JfwT1h1fHq+5XRCsM=
unbindall
bind "TAB" "_impulse19"
bind "ENTER" "_button2"
bind "ESCAPE" "togglemenu"
bind "/" "_impulse14"
bind "0" "_impulse10"
bind "1" "_impulse0"
bind "2" "_impulse1"
bind "3" "_impulse2"
bind "4" "_impulse3"
bind "5" "_impulse4"
bind "6" "_impulse5"
bind "7" "_impulse6"
bind "8" "_impulse7"
bind "9" "_impulse8"
bind "[" "_impulse15"
bind "\\" "_mlook"
bind "]" "_impulse14"
bind "a" "_moveleft"
bind "c" "_movedown"
bind "d" "_moveright"
bind "f" "_impulse11"
bind "q" "_impulse9"
bind "r" "_impulse13"
bind "t" "clientMessageMode"
bind "y" "clientMessageMode 1"
bind "z" "_zoom"
bind "BACKSPACE" "clientDropWeapon"
bind "PAUSE" "pause"
bind "UPARROW" "_forward"
bind "DOWNARROW" "_back"
bind "LEFTARROW" "_moveLeft"
bind "RIGHTARROW" "_moveRight"
bind "ALT" "_strafe"
bind "CTRL" "_moveDown"
bind "SHIFT" "_forward"
bind "DEL" "_lookdown"
bind "PGDN" "_lookup"
bind "END" "_impulse18"
bind "F1" "_impulse28"
bind "F2" "_impulse29"
bind "F3" "_impulse17"
bind "F5" "savegame quick"
bind "F6" "_impulse20"
bind "F7" "_impulse22"
bind "F9" "loadgame quick"
bind "F12" "screenshot"
bind "KP_LEFTARROW" "_moveUp"
bind "KP_END" "_speed"
bind "KP_INS" "_impulse13"
bind "MOUSE1" "_attack"
bind "MOUSE3" "_zoom"
bind "MWHEELDOWN" "_impulse14"
bind "MWHEELUP" "_impulse15"
seta radiant_entityMode "0"
seta gui_mediumFontLimit "0.60"
seta gui_smallFontLimit "0.30"
seta net_socksPassword ""
seta net_socksUsername ""
seta net_socksPort "1080"
seta net_socksServer ""
seta net_socksEnabled "0"
seta win_ypos "22"
seta win_xpos "3"
seta sys_lang "english"
seta s_numberOfSpeakers "2"
seta s_doorDistanceAdd "150"
seta s_globalFraction "0.8"
seta s_subFraction "0.75"
seta s_playDefaultSound "1"
seta s_volume_dB "0"
seta s_meterTopTime "2000"
seta s_reverse "0"
seta s_spatializationDecay "2"
seta s_maxSoundsPerShader "1"
seta r_debugArrowStep "120"
seta r_debugLineWidth "1"
seta r_debugLineDepthTest "0"
seta r_cgFragmentProfile "best"
seta r_cgVertexProfile "best"
seta r_forceLoadimages "1"
seta r_shadows "0"
seta r_skipBump "0"
seta r_skipSpecular "1"
seta r_skipNewAmbient "0"
seta r_renderer "best"
seta r_brightness "1.595238"
seta r_gamma "1.3"
seta r_swapInterval "0"
seta r_useIndexBuffers "0"
seta r_customHeight "486"
seta r_customWidth "720"
seta r_fullscreen "1"
seta r_mode "4"
seta r_multiSamples "0"
seta image_ignoreHighQuality "1"
seta image_downSizeSpecularLimit "64"
seta image_downSizeBump "1"
seta image_downSizeSpecular "1"
seta image_useCache "1"
seta image_cacheMegs "128"
seta image_cacheMinK "10240"
seta image_usePrecompressedTextures "1"
seta image_useNormalCompression "1"
seta image_useAllFormats "1"
seta image_useCompression "1"
seta image_roundDown "1"
seta image_forceDownSize "0"
seta image_downSize "1"
seta image_lodbias "0"
seta image_anisotropy "0"
seta image_filter "GL_LINEAR_MIPMAP_LINEAR"
seta gui_filter_gameType "0"
seta gui_filter_players "0"
seta gui_filter_password "0"
seta net_master4 ""
seta net_master3 ""
seta net_master2 ""
seta net_master1 ""
seta net_clientMaxRate "16000"
seta net_serverMaxClientRate "16000"
seta m_strafeSmooth "4"
seta m_smooth "1"
seta m_strafeScale "6.25"
seta m_yaw "0.022"
seta m_pitch "0.022"
seta sensitivity "5"
seta in_alwaysRun "0"
seta in_freeLook "1"
seta in_anglespeedkey "1.5"
seta in_pitchspeed "140"
seta in_yawspeed "140"
seta gui_configServerRate "0"
seta com_guid ""
seta com_showFPS "1"
seta com_purgeAll "1"
seta com_machineSpec "0"
seta g_decals "0"
seta g_projectileLights "0"
seta g_doubleVision "0"
seta g_muzzleFlash "0"
seta mod_validSkins "skins/characters/player/marine_mp;skins/characters/player/marine_mp_green;skins/characters/player/marine_mp_blue;skins/characters/player/marine_mp_red;skins/characters/player/marine_mp_yellow"
seta g_mapCycle "mapcycle"
seta g_voteFlags "0"
seta g_gameReviewPause "10"
seta g_countDown "10"
seta g_password ""
seta g_showBrass "1"
seta g_showProjectilePct "0"
seta g_showHud "1"
seta g_showPlayerShadow "0"
seta g_showcamerainfo "0"
seta g_healthTakeLimit "25"
seta g_healthTakeAmt "5"
seta g_healthTakeTime "5"
seta g_useDynamicProtection "1"
seta g_armorProtectionMP "0.6"
seta g_armorProtection "0.3"
seta g_damageScale "1"
seta g_nightmare "0"
seta g_bloodEffects "1"
seta ui_showGun "1"
seta ui_autoReload "1"
seta ui_autoSwitch "1"
seta ui_team "Blue"
seta ui_skin "skins/characters/player/marine_mp"
seta ui_name "Player"
seta si_spectators "1"
seta si_usePass "0"
seta si_warmup "0"
seta si_teamDamage "0"
seta si_timeLimit "10"
seta si_fragLimit "10"
seta si_maxPlayers "4"
seta si_map "game/mp/d3dm1"
seta si_gameType "singleplayer"
seta si_name "DOOM Server"
seta g_spectatorChat "0"
After I that game runs at bearable frame rate and I must say this is a beautful game!
on Dec 08, 2009 | Computers & Internet
I HAVE 3 60% ON MY RESULTS AND 49% CANT I APPLY FOR SETA BURSARY
sadly we here on FIXYA can not assist you with this .
Mar 08, 2017 | Computers & Internet
Signin Seta Saatjian
I can't loguin fecebook in my tablet
Nov 12, 2013 | Facebook Social Network
Ghow to close front cover door of HP Laser jet 1020
If it does not easily close it usually means that the toner cartridge is not setaed properly. Gently remove the cartridge and reinsert. It should go further in and you should then be able to close the door easily.
Oct 04, 2013 | HP LaserJet 1018 Printer
PRINTER ERRO TEMPERAT FUSORA
Olá Primeiro:
1. Troque seu no-break, estabilizador ou transformador por um com capacidade maior que 1000Watts.
2. Ligue a impressora e agurarde apresentar a mensagem ERROR PRINTER TEMPERAT FUSORA
3. Pressione Seta pra Baixo.
4. Apeter: *
5. Aperte: #
6. Presisione: OK
7. Substituir 0 pelo 1
8. Pressione o Botao Vermelho.
9. Depois: Seta pra Baixo.
10.# (entra no modo apagmento)
11. Apertar letra T
12. Desligar impressora por 5 segundos e religar
13. Repita o passo 3 a 8 porém, substitua o 1 pelo 0 (voltando ao normal).
14.sua impressora deve voltar ao normal.Este problema é ocasionado por oscilação de energia.
Mar 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Upgrade Hard drive
If you open the case and you can see the seta plugs then yes you should be able to install a seta drive. Since the settings are in bios and seta is becoming more of a norm I would assume you will be able to do this with minimal effort. Remember to look at your power supply leads to make sure you have the appropriate plugs. if not you can get an adaptor if one is not supplied with the drive.
Dec 23, 2008 | Dell Dimension 4600 PC Desktop
How to change ringtone for message
go to menu and click on ringtones and gotto setas and choose message alerts or you will find it in message settings which iis under menu then messages then settings hope this is useful
Jul 04, 2008 | Motorola Cell Phones
Retail Supplies Logo
55 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
