Question about Singer Sewing Machines
My needle is hitting the metal plate on a singer cg590 sewing machine. Is there a way to adjust it back into its correct position?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
Your needle plate may have been place incorrectly, and it's easy to do. Even the slightest variation can cause the needle to hit it. Try taking the metal plate off and then reseating it -- testing the needle position before you tighten the screws.
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
kent581
  • 87 Answers
SOURCE: The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Posted on Mar 18, 2009
bunnydawg
  • 5158 Answers
SOURCE: My sewing machine needle is hitting the top of the needle plate
basically have to bend it carefully back by hand.... if you have a straight edge or even a small leveler (the kind with a bubble) you can check which direction it is bent and gently bend it back a little each time.
Posted on Mar 29, 2009
I was sewing with my CG590 singer machine and then my needle broke. So I put in a new needle, and now it seems like it is hitting something when it goes down. What could this be and how do I fix it?
If the needle hit something (which is usually what happens when the needle breaks), it could very well have knocked the machine out of time. You can try installing another needle (make sure it is installed facing the correct direction) and see if that changes things. If it continues to hit something, you can search the internet for web sites and videos discussing "sewing machine timing" or take it for service.
Nov 12, 2016 | Singer CG590 Mechanical Sewing Machine
Singer CG500 Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Machine has yet to be used!!
Unless you need all the bells and whistles to sew get you a pre-1930 treadle or handcrank. I have 2 electric Singers, 1947 model 66 and 1948 201-2 both with attachments. Also I have 1903 Singer handcrank made in Scotland. The plastic new one just don't have the ability to hang in there .... All my pre 1930 Singers sew... I love them!
Apr 17, 2014 | Singer CG500 Mechanical Sewing Machine
Neddle hits hook plate+how to fix
check needle is straight and fitted correctly
Mar 06, 2014 | Singer CG590 Mechanical Sewing Machine
Cg590 timing
with needle in centre sewing position remove bobbin cover, needle plate, bobbin etc until you can see hook. turn balance wheel towards you until needle at lowest point then turn slowly until needle rises 3/16" hook should be behind needle just above the needle eye
Jan 02, 2014 | Singer CG590 Mechanical Sewing Machine
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
Make sure it’s attached securely.
A needle that hits a pin can break. Always remove the pins from your fabric before they reach
your needle.
Make sure it's securely in position.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
Singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Apr 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
