Question about The Music
Is there a fuse inside the xr 8600 power mixer?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • The Master
  • 572 Answers
.. F100 & F101 - could be board mounted? I don't have a unit to compare :-) Good Luck!
Posted on Apr 10, 2017
  • 33 Answers
I see 2 on the schematic..... F100 & F101 - could be board mounted? I don't have a unit to compare :-) Good Luck!
Posted on Apr 02, 2017
Peavey XR series 600 may have been left on without one speaker plugged in, what is the likely diagnosis?
Out put amplifier is defective. If it was protected by a fuse - then look for a fuse that is blown.
Sep 27, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey amp
Most likely a power supply problem. Take it to the repair shop.
Apr 06, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Sep 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have a peavey 8600 powered mixer. If i run powered speakers through the main output on the front will I not have effects?
If you run the speakers FROM the main you should have BOTH the effects and the EQ invilved with your signal.
Apr 20, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Will not power up
Check mains fuse, internal fuse and try new mains lead
Jan 20, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I want to use both speaker outputs for loudspeakers on my Peavey 8600 without splitting the watts. How do I hook up monitor speakers in this situation? Can another mixer be patched into the front? I have...
Sorry, but this unit does NOT support "bridged" mode. You will have to drive seperate speakers from the two seperate outputs. You would NOT get any more power if you could do bridged mode than you could with 4 ohm speakers on each of the two output channels.
Nov 27, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Music Logo
27 people viewed this question
Top The Music Experts
John mullen
Larry Stiles
Larry Stiles
D. E. Hev
Are you a The Music Expert? Answer questions, earn points and help others
