I use vw708 suddenly ders no noise and wen I switched off the machine I can't open the door.
2 Suggested Answers
  • 157 Answers
SOURCE: while switchin on 311oc it blinks thrice n again switch off
ur got software problem so go to ur nearset nokia n tell him to change ur software
Posted on Jun 06, 2009
I have a fisher paykel smart drive 7,5 kg was working fine and the other day it just stopped no lights to indacate the powers on no beep wen u push the button just make a slight humming noise wen you press...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The humming noise can be fault in the motor or a fault in the capacitor to the motor.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 17, 2011 | Fisher and Paykel Washing Machines
Hi mine is a 8gb transcend memory card.i tried formatting it thru card reader but it was not possible as i didnt get the option of removable disk.wen inserted in my cell im not able to access it..there is...
Based from the troubleshootings you have done, your memory card may have already gone bad. Unfortunately, no other troubleshooting can be done. It will need replacement.
I hope this works for you.
Mongkey
"Understanding explains better..."
Jan 27, 2011 | SanDisk 2GB microSD Memory Card
2001 R6 press the electric tart button and it buzzes
hi...
der may b several reasons
1. charge in battery may b low so try t after changing the battery
2.der may b some short circuiting occuring wen u press the start button
3.the is too much load on the starter motor which wen starting current in more picks up and gradully reduces its speed.
4.motor insulatioin may be gone so short circuiting may occur inside motor.
so plz check all these things...
Jul 04, 2010 | 2000 Yamaha YZF-R6
Door chime doesnt stop
hi
dis is due to the pressing switch not working.which stops the chime wen the door closes. so check it weather it is in good condition. replace it it wil b oki. if not check the wiring which is comin to the switch, der may be some problem with the wiring system.
Jul 04, 2010 | 1992 Volvo 240
Psp makes buzzing noise and only makes sound when headphones are used
meine psp hat störungen weil ...wo ich gestern aufs sofa gesesen bin hab ich von der psp musik gehört und plötzlich wo ich auf steh mit der psp in der hand ist der sound aus und geht nicht mehr wen ich höre dan knakst es und raschelt und ich weis nicht warum? ich habe version 6.20
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
While switchin on 311oc it blinks thrice n again switch off
Jun 06, 2009 | Nokia 3110 Cellular Phone
Ice Maker Making Noise
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Washing machine makes beeping noise
It sound like a lid switch problem .A defective lid switch will notice of an open door when actually door is physically closed, and will prevent washer's spining and function at all. The switch located inside the machine near the door frame. You should open the top panel (open 2 screws and then slide it out) and you will have an access to it . You can test it by multi-meter (it is an on/off switch). In case of a deffective switch, it should be replaced. Be aware that you should remove machine's power cable before starting your test !!!! Good luck !!!
May 30, 2006 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
