Question about Cell Phones
I need help getting my voicemail working. - Cell Phones
How to set up voicemail
Dial your own phone number, usually that brings you to your voicemail, and it should bring you to your voicemail options if that is correct. If this dooesn't work you should just contact the service provider and ask them.
Sep 02, 2012 | Doro PhoneEasy 410 Cell Phone
Cant get into voicemail.
HI honore3 if you can not get into your voicemail. YOu can do 2 things the first thing you need to call your carrier's customer service . They can help you reset yout voicemail password. after that you will need to see if you can get into yout voicemail.
Mar 18, 2011 | Cell Phones
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Hi there, Feature 983 gives me inactive feature message, can't forward calls, voice mail not working, etc. We had a short power outage the night before these symptoms began. Do I need to turn the power off...
Cycle the power on the voicemail system and that should solve the problem. If you still get the "Feature inactive" message, you may have to replace the voicemail power supply or get the voicemail system repaired.
Good Luck!
Dec 21, 2009 | NorStar Cics 6.1 & Call Pilot 100...
LG600G tracfone voicemail problems
My recently purchased LG600G (Target $30) immediately started receiving unwanted calls that forced me to figure out voicemail. Well, when I say "immediate", I mean once I struggled through the activation process! Turns out I wasn't pressing, and holding, one of the keys. The first of many firmware issues, read on.
Ironically, the phone is not by default setup to use the keypad for entering responses and I needed to enable DTMF tones. 9 Settings, 5 Call, 7 Send DTMF Tones. (btw, p.62 of the manual lists menu options 9.5.8 which is wrong). Select 1 then set.
I was then able to check my voicemail but my phone still doesn't actually let me hear the DTMF tones. I also have to hold the keys down longer than other phones; it doesn't like flying fingers.
Usually I check voicemail using a land line (or my wife's free work cell!). My local number is not my area code. For AT&T the requested mailbox is the cell number, followed by the 4-digit passcode.
Hope this helps somebody,
N
Jul 01, 2009 | Cell Phones
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Aug 28, 2008 | Motorola Mobility RAZR V3
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
RAZR V3 voicemail problem
have you set your voicemail yet? you need to set your voicemail in order for it to work.
Jan 24, 2008 | Motorola Mobility RAZR V3
Adding voicemail to an existing extension
You need to build the mailbox in f983
Log 1020000
Mbox
Add or Change.
When you get to mailbox enter the extension # of the new telephone.
When you get to extension number-enter the same extension number.
Oct 25, 2007 | NorStar Compact Ics WithClid Trunk Mod...
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
