Question about Cell Phones
I can't get my voicemail to work. - Cell Phones
How do I disable ee home phone voicemail
try the following
send a text with the phrase remove voicemail divert to 150 will cancel the voicemail divert
(sending a text with the phrase voicemail divert to 150 will re-enable the voicemail service).
if that doesnt work ring EE customer service they can do it for you
May 03, 2017 | Lands Phones
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I have voicemail through my telephone company. Recently my panasonic phone system kxt7731 has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left...
I have voicemail through my telephone company. Recently my SAMSUNG SGH-D980 phone system has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left messages that I cannot retrieve! I would like to "turn off" the voicemail function of my phone system. I'm not sure why the phone changed from working "properly" to now picking up voicemail calls. Thank you for any help you can give me!
Sep 14, 2009 | Cell Phones
Voicemail doesn't work
I would check with your cellular provider to make sure that they kept your voicemail when you purchased the new phone.
Jun 02, 2009 | Motorola Mobility RAZR V3
FSK Voicemail Indicator not working
When you press the voicemail button on your phone it is retrieving messages stored internally in your phone. Verizons Voicemail is a seperate entity where the message reside on the server. If you do not want to use the Verizon Voicemail, simply call the business office and ask them to remove voicemail completely from the account. That way your phones internal answerming machine whille then catch all the voicemails and you can go back to using your voicemail button to listen to them. Hope that helps you and everyone else out.
Tony T.
Jan 01, 2009 | Motorola Mobility C70 MD7081 5.8 GHz...
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Oct 17, 2008 | NorStar Flash Voicemail Power Supply Only...
Voicemail does not work
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Jul 14, 2008 | Apple iPhone 3G
Voicemail password
call your provider and ask for it and they'll give it to you.. gud luck man
Apr 27, 2008 | Motorola Mobility RAZR V3
RAZR V3 voicemail problem
have you set your voicemail yet? you need to set your voicemail in order for it to work.
Jan 24, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
