Question about Vacuums
Brush wont spin - Vacuums
  • Vacuums Master
  • 1,509 Answers
Replace the belt if your model has one
Posted on Jan 03, 2017
Change brush indicator light
If the light is not glowing it means the brush roll is not spinning. The belt may be stretched and need replaced. The brush roll may be installed improperly. The magnet in the brush roll has to be aligned with the indicator light for the light to work when. The brush roll is spinning
Mar 30, 2014 | Kirby G4 Bagged Upright Vacuum
Dyson dc 35 the floor brush wont rotate
My brush on my Dyson DC35 wont spin.
Feb 29, 2012 | Dyson DC35 Handheld Vacuum
Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Brush wont spin
Was the belt worn or broken? It probably needs to be replaced. Here is the belt you need:
Dyson DC07 Belt
Apr 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush on ours wont spin
Take out the brush roller. (turn the plastic lock mechanism with a coin or screwdriver, pull out the plastic holder, and the brush will pop out). The brush roller has two white caps on the ends. Chances are, one or both of these caps have moved out just a bit, putting too much force on the delicate motor. Simply push the caps back firmly into place. Make sure the brush and the surrounding area is clean, put back in and It should spin .
Feb 25, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Brush wont spin, belt is perfect
It sounds like the motor that spins the beater brush is burned out,If it is under a yr old it should be covered by the manufacturer warretee. Find a Hoover service center that does warrentee repairs.
Jan 25, 2010 | Hoover U8188-900 Bagless Upright Vacuum
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes wont turn
Remove the brush block, turn the unit on its side and watch the square hole to see if it rotates. If not, then the turbine(#23) isn't working, if it is, then is the shaft on top of the brush block broke off, if it is, replace the brush block.
Jul 01, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
