Question about RCA Televison & Video
2025B2-B1 won't control RCA RTS7019BE6 sound bar
Once I have my sound bar (RCA Brand) hooked up to my T.V. (Insignia), how to I get sound from it or turn it on?
How did you connect the sound bar to the TV? The remote that comes with the sound bar should control everything... PLEASE read the operators manual first...
Jul 25, 2017 | Televison & Video
When i hooked up my sound bar to my tv with an rca jack no sound comes from the sound bar wy
I think you should use remote control. Press input button and select AV.
Nov 22, 2016 | RCA Televison & Video
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Connected an RCA sound bar to my RCA tv an the remote control wont work anymore
You may have situated it so it is blocking the pickup for the remote. Your remote is talking but the TV can't hear it. Make sure no part of the front is blocked by the sound bar.
Apr 02, 2015 | RCA Televison & Video
Why is the sound on my new sound bar only going up half way?
Connect the sound bar to your cable box audio outputs--best way is optical. Then set the cable box volume to high and control the volume from the sound bar
Jan 12, 2015 | Craig Soundbar with Bluetooth
How do I get operating instructions for this sound bar
1. Plug it into a power outlet and turn it on.
2. Put 2 AAA batteries in the remote control.
3. Dock your iPod or iPhone into the docking connector.
4. You can hook up the sound bar to your PC (from the RCA(L/R) audio output on your TV to the RCA audio input on the bar) or to your PC (from the headphone jack on the PC to the LINE IN jack on the bar). Obviously, you can hook it up to both TV AND PC only if those two are located close to each other.
5. Using the remote, select the audio source/input you want to listen to: iPod/iPhone, FM Radio (an FM tuner is built into the sound bar), TV or PC.
Hope this helps.
Dec 20, 2014 | Apple Ilive Itp100b 2-channel Speaker With...
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Intel Corporation 82801BA/BAM AC'97 Audio Controller (ICH2/ICH2-M B1/B1' steps)a need driver
1st Download Driver from this site Intel Sound Drivers
Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
Jul 03, 2009 | Computers & Internet
Televison & Video Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
