Question about Home
I have a older Atomic clock-put new batteries in it and hit the reset button-it was on Eastern time now it's on Pacific time and I can't get it back on Eastern?
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Posted on Apr 04, 2009
homedesigner
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
SOURCE: I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Posted on Feb 24, 2010
SOURCE: I have Medion Atomic Clock Model md 10954 but have
1) use the MODE button to select the weekday instead of the seconds
2) press and hold the UP button for 2 seconds, continue holding until the desired time zone is reached
Posted on Nov 21, 2010
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
    Hi lufberg,
    I see you need help with your radio controlled clock.
    Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
    Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
    I hope this will help.
    Thank you for choosing Fixya,
    mvincentc
    Jul 04, 2011 | Vacuums
    SkyScan Atomic Analogue Clock # 28512
    read the manual here
    http://www.skyscan.info/content/manuals/15-model-28500.html
    There are four buttons on the back, at the bottom. From left to right they are Pacific, Mountain, Central and Eastern
    Jan 22, 2010 | Audio Players & Recorders
    TIME ZONE SETTING
    Mar 08, 2009 | Watches
    Resetting the atomic clock to the correct time zone, and outside temp to work.
    For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
    For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
    Good luck,
    Doc
    Dec 01, 2007 | Baby Gear
    Honeywell RC182WB Atomic Alarm Clock with Temperature--stuck on pacific time!!!
    I KNOW HOW TO FIX IT!
    Take off the battery cover, and take the batts out, leaving the outside thermometer working...
    You will have to reset everything but it automatically detects your time zone!
    I just did it literally 2 minutes ago!
    Nov 23, 2007 | Honeywell RC182WR Atomic Alarm Clock - Red
    Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
    Home Logo
    27 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
