Question about Kenwood Radio Communications
Where can I obtain a DDS module for a Kenwood TS-50
2 Suggested Answers
vtu1314
  • 1335 Answers
SOURCE: Where can I get a DDS module for a TS-50?
Try a junk yard
Posted on Dec 19, 2016
How to install a voice synthesizer into a Kenwood ts 570
This should be of some help to you...
http://www.manualslib.com/manual/86121/Kenwood-Ts-570d-Ts-570s.html?page=64
Mar 02, 2015 | Kenwood Radio Communications
Why does my Kenwood TS 790 E when pressing call button causes C2 fault on display?
http://www.iw2nmx.it/Kenwood%20-%20Trio/TS-790%20Instruction%20and%20Service%20Manuals%20plus%20mods/TS-790%20Instruction%20Manual.pdf
Jul 14, 2014 | Kenwood Radio Communications
2007 gmc heated mirror module
Could have a DDS an PDS .depends on what RPO code yours has >
Outside Mirror Description and Operation (with RPO DL3)
Or
Outside Mirror Description and Operation (without RPO DL3)
Without
Heated Outside Rearview Mirror Operation
The REAR DEFOG relay controls the operation of the heated outside rearview mirrors. When rear window defogging is requested, the REAR DEFOG relay is energized and B+ is applied to the supply voltage circuit of the mirror heater element, located in the mirror face. A constant ground is also applied to the mirror face. Current will pass through the mirror heater element, warming the mirror, so long as the rear window defogger is commanded ON.
With
The DDS and PDS control the activation of the mirror heaters. Upon receiving a serial data message indicating a request for heated mirrors, the DDS and PDS, will apply voltage to the mirror heater element supply voltage circuit. The mirror heaters will remain active until a new message is received indicating rear defogger is to be deactivated.
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a four position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a three position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Mirror Extend/Retract Switch--Integrated into DDS and is a two position switch that allows the operator to select the mirror extend or mirror retract position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Folding Mirror Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Your best bet mite be to take to a qualified repair shop , i really don't think you'll be able to do anything with it.
Do you have wiring diagrams so you know which wires to test ,do you know how to do electrical testing ?
The Driver Door Switch (DDS) and Passenger Door Switch (PDS) supply voltage to the outside rearview mirror heater elements upon receipt of a serial data message from the HVAC module indicating that the rear defrost system is active. The door switch supplies B+ through the driver/passenger mirror heating element supply voltage circuit when a request is seen. Ground is applied through the driver/passenger mirror heating low reference circuit.
Sep 15, 2017 | 2007 GMC Sierra 2500HD
How hard is it to replace the finals in a kenwood ts-2000
Hi Damon,
It's Bloomin' hard, and it's tricky if you have little technical knowledge.
Yes Kenwood is a darn good brand, so to keep your Kenwood darn good, pay for the repairs, it's darn worth it.
Cheers,
Peter
Jul 02, 2012 | Kenwood TS-2000
I have a 08 chevy avalanche the driver side front and rear door locks won't work when I use my keyless entry button or on the inside driver panel. Could it be a fuse? Passenger side works fine I try...
Do the power windows work ? DDM - driver door module fuse 15 amp - location is the instrument panel fuse box , plus LT DR circuit breaker 25 amp. Circuit breakers rarely go bad . The power locks are controlled by electronic's .The passenger side has another power supply ,that's why they still work .
Door Lock System Components
The power door lock system consists of the following components:
• The driver door switch (DDS)
• The passenger door switch (PDS)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock/unlock relay (LBEC)
• The reversible door lock actuators in each of the doors and liftgate
The front power door lock switches are integral components of the driver door module (DDS) and passenger door module (PDS). The switches are 2 position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDS or PDS. The DDS or PDS monitors these inputs and sends a LAN message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the LAN message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock/unlock relay and also send a LAN message to the DDS and PDS to perform the appropriate function.
The modules which activate the power lock motors are:
• The DDS (driver door lock actuator)
• The PDS (passenger front door lock actuator)
• The BCM (both rear door lock actuators and cargo door/liftgate)
The DDS and PDS are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and endgate doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. The energized the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
It's possible you have broken wire or wires inside the flex boot from the body of the vehicle to the driver's door . This happens a lot .
Fuse Block - I/P instrument panel
Left of the I/P behind the side trim panel
Mar 04, 2018 | 2008 Chevrolet Avalanche
2008 Chev Suburban 4wd Z71 1/2 ton; several items on my passenger side stopped working: my passenger side front seat heater stopped working; the passenger side electric mirror stopped working; the signal...
Power windows an locks work ok ? Do you know anything about automotive electeronic control modules ?
Power Mirror System
Power Mirror System Components
• Power Mirror Direction Switch--Integrated into DDS and is a 4 position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a 3 position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Memory Switch, if equipped with memory mirrors--Supplied power by the DDS and provides a voltage signal to the DDS upon a switch activation
• Powertrain Control Module (PCM), if equipped with memory mirrors--An electronic control module that requires programming when replaced and provides the message indicating transmission gear selection
• Driver Information Center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a an electronic control module that requires programming when replaced and is used to personalize the memory recall functions
• Fold Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1023
Circuit/System Description
The driver door switch (DDS) and front passenger door switch (PDS) each contain switches that control power door lock and window functions. The DDS also contains the control switch for the power outside rear view mirrors. These switches are integrated within the door control modules and are not serviceable as separate components. The DDS and PDS monitor these switch inputs for internal faults and set B1023 00 if any are detected.
You could have any number of problems an without testing , hooking up a scanner that can check DTC'S in the door module ,electrical circuit testing etc... we'd only be guessing . Your best bet mite be to take it to a qualified repair shop.
Feb 15, 2018 | 2008 Chevrolet Suburban
TS 2000 KENWOOD TRANCEIVER
I have the same problem with my TS2000 , in VHF I can heard small signals only if I turn on the PRE Amplifier ...
It start just few hours of use .
Jul 31, 2008 | Computers & Internet
Radio Communications Logo
56 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
