I am using a SE-S2000 and can not clear a E001
2 Suggested Answers
jackcity
  • 34 Answers
SOURCE: I am using a SE-S300 and can not clear a E001
E001 = Wrong Mode, which means u had did something in another key mode but not yet done.
Solution 1 :
1. Turn the key to another position where the screen do not show E001
2. Press [Subtotal]
3. O.K
Solution 2: Flag Clear the Machine
1. Key turn to OFF
2. Keep Press [FEED]
3. Key turn to PGM
4. Release [FEED]
5. U will see "INIT 0000000000"
6. Press [Subtotal]
7. U will see "FFFFFFFFFF"
8. Wait for 10 seconds, the machine will print
9. OK
Posted on Nov 15, 2009
Casio se s2000 not printing
You must never remove the batteries without leaving the power turned on. The register will lose all programming if you do this. Error 4 normally means all program lost, ready for new program. The printing may have stopped due to this. If it still has batteries, you might be able to recover the memory by following the instructions under 'clearing a machine lockup' near the end of your manual. If you have lost the manual, one of the users has one here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S2000_users_and_programming_manual.html
Aug 10, 2014 | Casio Cash Register
Hi I have a casio s2000. I reset it and now it has changed the display from pound to dollars , how can I change it back to pounds?
I think the proper model number may be : PCR-T2000 and you will need to download the manual here:
http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
May 11, 2014 | Casio Cash Register
How to change currency symbol in SE-S2000?
Try to check from these options or check there manual from this link
http://www.jrpos.co.za/manuals/Casio-SE-S2000-User-Manual.pdf
True True (``````````` (``````````` 0 7566660 5089579 c:\users\hp\appdata\local\temp\msohtmlclip1\01\clip_image002.jpg
I hope this information will be helpful. Thank you for using FixYa!
Jul 17, 2012 | Computers & Internet
How to fix e035 error on se-s2000
I tried your suggested fix Electroboy and all it did was print out some end of year totals or something that used about 5 metres of paper, I managed to get help from the Hotpos tech support guys and they gave me this sequence which immediately fixed the problem......
Turn key to program
Press
subtotal
0
0
0
0
cash
subtotal
Turn key back to reg
That's it :)
Apr 11, 2012 | Casio Parts Cash Register PC Desktop
How to fix an error E008 for SE-S2000?
You need to log on to the register. Try 1 CLK#
If anyone needs more information, the Casio SE manuals are here:
SE-S10 Operation and programming manual http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S10_user_manual.html
SE-S10 Service (repair) manual http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S10_PCR-T280_PCR-T280L_PCR-T290L_service_manual.html
SE-C300, SE-C2000, SE-S300, SE-S2000 dealer programming manual http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-C300_SE-C2000_and_SE-S300_SE-S2000_dealers_manual.html
SE-S6000, SE-C6000 dealer programming manual http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S6000_SE-C6000_dealer_CA_Ver_manual.html
SE-S6000, SE-C6000 Service (repair) manual http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S6000_SE-C6000_service_manual.html
Sep 20, 2011 | Casio Parts Cash Register PC Desktop
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
Aug 03, 2011 | Canon iR 2016i Black and White Copier
E00001-002 Error cod?
Thanks for using Fixya.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I am using a SE-S300 and can not clear a E001 error code!! Any ideas??
Solution 1 :
2. Press [Subtotal]
3. O.K
1. Key turn to OFF
3. Key turn to PGM
4. Release [FEED]
6. Press [Subtotal]
9. OK
Nov 15, 2009 | Casio Parts Cash Register PC Desktop
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
23 people viewed this question
k24674
jasbo
jasbo
