Have Cassida 6600 and reading Err C. Cleaned machine well & checked for stuck bills. Turned on & off the machine many times but same Error and won't work. Anything else to try? Thank you!
IFIXALL
  • 868 Answers
SOURCE: machine stuck on pause/err
un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
Gryfox
  • 216 Answers
SOURCE: Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
Posted on Dec 06, 2008
SOURCE: busy, try later error won't go away
depending what rollers and how you did it, you probably have 'spun' a clutch out of position so it can't find it's 'home" position, and keeps on trying. If it worked before cleaning and now it doesn't you've definitely broken or dislodged something like that.
Posted on May 28, 2009
SOURCE: Getting disk err/unable to read msg w/all disk.
Needs the dvd drive replaced. We are a listed repair service on this site.
www.videogamerepairservice.com
Posted on Mar 14, 2010
  • 5612 Answers
SOURCE: I have a 2004 Ford Explorer and when you turn the
Hello, What you are saying is the starter will turn if you jump the starter Relay. If you want to try this a second time, make sure the Ignition switch is in the RUN position. It should start.
Be sure to have the vehicle in Park. There are some Interlocks in the gearshift and Brake pedal that prevent when certain things happen. When your vehicle is in Park or Neutral, the power wire from the Ignition switch can make a connection to the wire that controls the starter Relay.
But first this wire has to get the okay from the Interlock switch, that the gearshift IS either in Park or Neutral. If this switch is bad or misaligned, the connection will not reach the starter Relay. You need to take off the small wire at the starter Relay and hook up a test light or meter. Then turn your Ignition key to START. The small wire should have power when the key is held in the start position.
If the small wire does not have power, then everything connected to that wire needs to be traced back to the Keyswitch. The cables or rods that move in the gearshift or steering column may be out of adjustment. Not too expensive to correct.
I hope my solution is very helpful to you.
Posted on Jul 21, 2011
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
ERROR E38
Found manual here with all error codes. It's in Russian though..
http://www.rservice.by/files/manual/cassida/counters/Cassida%20Billcon%20N120%20User%20Manual%2028.11.2013.pdf
Mar 24, 2014 | Billcon N-131 Money Counter
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
Err code 322 every time ces up on my HP 6600 print scan web copy n faxachine .
Video might not help but 322 is an error with the receiving fax machine due to poor telephone line conditions. Solution is to set the receiving machine to receive at a slower transmission speed if it still fais resend the documents in smaller sizes. Hope this helps
Apr 16, 2013 | Office Equipment & Supplies
System error at the end of installation of software
This error usually comes in Nokia 6600, N70, N72 and N73. One of the reason for this is your phone is infected with virus then please format your phone and try to open the handset.
May 24, 2010 | Nokia 6600
Err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Apr 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
Error message
check out the drainage area of the machine is it cleaned or dirty.if dirty or any thing got stuck there just clean it to avoid the error again.
Sep 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
