Question about ASUS Computers & Internet
Asus Laptop with windows 10,L555 screen flickers while on battery, battery is still at 78%. Stops immediately when its plugged in. Is there a fix?
    Top Expert:
  • ASUS Master
  • 8,204 Answers
Try another battery and see if it does the same if it does then you know its the battery.
Posted on Dec 21, 2016
Testimonial: "Can't change the battery, I don't know how, store wants to charge 100.00 to do it."
  • NOEL
    NOEL Dec 22, 2016
    the battery is in the bottom left under the laptop it should be just a couple of small screws to undo if its the small square battery.
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
Asus x83v won't boot up
Unplug the machine, remove battery, leave the battery out, plug in the machine, try to boot normally. If the fails unplug, plug in, push the on/off button and IMMEDIATLY start tapping the F-11 REPEATEDLY. Enter restore/recovery section select a date before this problem started and restore. If that fails do a system recovery to factory settings. Or if you have a Windows Vista repair disk, Windows Vista Install disk that you can use to repair
Nov 12, 2012 | ASUS Computers & Internet
What's your problem?toshiba satellite l555 s7916 wil not boot
Try Resetting the CMOS on your Motherboard.
Turn off the Laptop and unplug it
Remove the battery
undo the RAM cover
Remove the RAM
plug the laptop into the power
Turn the PC on and listen for some beeping noises
If you hear the beeping noises turn the laptop back off
Unplug the charger
Replace the RAM into the RAM slots
Replace the the battery
Plug in the laptop and power it up.
if you get video output, that's Great, if not, it's possible that you have a faulty screen
Oct 05, 2012 | Toshiba Satellite L555-S7916 Notebook
Powering up but black screen
backlight on screen doesnt work
Apr 05, 2012 | ASUS Computers & Internet
Flickering screen
Try an external monitor to the laptop and see if it flickers. If it does, more than likely your video card is going bad. If it does not flicker on the external monitor you probably have a loose video cable or lcd inverter cable. Go back inside and remove the 2 cables that go into the LCD Inverter that sits at the bottom of the LCD Screen, then plug them back in. Then unplug the video cable at the top behind the lcd screen, plug it back in and secure it with a piece of tape right where the two connections meet.
Mar 28, 2012 | ASUS U52F-BBL9 Laptop
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
When my toshiba l555 battery runs low, I can plug in the charger but it will not charge unless I close it and put it in sleep mode. The battery icon in the lower right hand corner will read "plugged...
This is a problem I recently went through also, on my Dell Inspirion 1420. What you should do is replace the battery of the laptop, that fixed it for me. Laptop batteries are easy to find and replace, and you almost never have to open up a laptop to replace the battery. Generally you can find the battery on the bottom of the laptop, near the part where the monitor meets the main body of the laptop. Unfortunately, laptop batteries aren't very cheap, usually $50-$100, but I quick searched a replacement battery and found one for $35 for the Toshiba L555 series here, pretty hard to beat, and from a trusted seller too.
Apr 05, 2011 | Toshiba Satellite L555-S7916 Notebook
I have an ASUS eee netbook. Recently the power cord hasn't been connecting well to the computer and now it doesn't even register. It's plugged in but isn't charging. Is it the cord or the laptop?
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
Nov 30, 2010 | ASUS Computers & Internet
Computers & Internet Logo
122 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
