Question about Samsung Dishwashers
Samsung Dishwasher....Light flashing in 'Heavy' mode. When pushing Start the pump goes on and off as if to pump water that isn't there. Cycling on and off. When pushing Power button, just chimes.
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
  • 901 Answers
SOURCE: Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
Posted on May 19, 2010
Why does heavy light flash and water pump run all the time?
You still have a problem elsewhere in the dishwasher--the light is most likely an error code flashing a certain number of times. If you replaced the main board and the same condition still exists, then the issue probably wasn't the main board but a peripheral device(main pump, drain pump, heater circuit, sensor, etc.) The new main board is sensing the continuing condition.
Aug 17, 2015 | Samsung Dishwashers
Why is the heavy light blinking on my samsung dishwasher
That is usually indicating a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Aug 03, 2014 | Samsung Dishwashers
Brand new Samsung Dishwasher DW7933LRA Flashing light "HEAVY" and will not start
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DMT400RHS Builtin Dishwasher
Heavy light flashing
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Mar 23, 2014 | Samsung DW80F600 24" Black Built-In...
My dishwasher will not start the heated dry light flashes constantly
Hello Daneil, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool 24 in. DP940PWP Free-standing...
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Dishwashers Logo
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
