Question about Dehumidifiers
I need a user manual for a Swan sh3030 dehumidifier.
My dehumidifier sh3030 is not collecting water but is running fine
You say it's running "ok", but there is no water discharge. If that is true then you have absolutely no moisture in your air and that is practically impossible. So we can say effectively that it is NOT running "ok". Fell the discharge air from the unit. If it is roughly room temperature rather than substantially warmer that than the air in the room, then you have found a problem. That problem would be that while the fan may be running, the compressor that heats that air and gets the condensation going is not. If you feel little or no air from the discharge, then you could have a clogged coil or filter (you checked that), or a bad fan.
Dec 11, 2016 | Dehumidifiers
HI HAVE GOT A SWAN SH3010 DEHUMIDIFIER BUT THE COIL KEEPS FREEZING OVER WHAT AM I DOING WRONG?
Nothing.That's how it works. The coil gets cold. The moisture(water) in the air freezes to the coil. The coil then gets warm and the ice melts, dripping into the bucket or out the drain hose.
Jan 04, 2015 | Dehumidifiers
I have a LAD704DUL frigidaire dehumidifier that will not shut off after being shut off, and not until the plug is pulled. Is this worth getting fixed
Dear Peter Nicolle,
according to the user manual the dehumidifier will not stop running for the following 5 reasons:
  • Windows or doors near dehumidifier are open to outdoors.
  • Area to be dehumidified is too large.
  • Air movement through dehumidifier is blocked.
  • Dehumidifier has been installed or restarted recently.
  • Dehumidifier is in the CONTINUOUS mode.
You can find more information on the user manual on page 9 under the category DEHUMIDIFIER RUNS TOO MUCH.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
Nov 30, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
Dehumidifiers Logo
109 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
