Question about The Toys
Double doll travel case instructions
2 screws come with the double doll travel case but there are 6 screws! Where do the 2 screws go?
SOURCE: Neff double oven
Hi, Have the same problem today.
Found the following on you tube that may help you!
http://www.youtube.com/watch?v=hSzc4Uqbbr8
Best Ian
Posted on May 25, 2008
SOURCE: Zebra S600
Mmmm a-Jamone
Posted on Aug 05, 2008
  • 44 Answers
SOURCE: cant install sims 2 double deluxe
Try to clean the disk with a cotton t-short or a cd cleaning cloth ($2 at electronics stores). Try again. If it still doesn't work, then your disk is defective. Call EA.
Posted on Jun 14, 2009
SOURCE: i need the code for the sims 2 double deluxe to instal it
You mean the cd key. Last i checked. this is something that should have come with a newly bought sims game. if you cannot find it, i suggest talking to your friend.
Posted on Aug 18, 2009
SOURCE: wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Posted on Mar 17, 2010
What are the best quality and affordable baby stroller in the market?
There are lots of stroller in market online and offline. If your budget is under $200 then go for Chicco single stroller. If budget $300 you will get travel system stroller Chicco brand. I hope Chicco travel system stroller is the best quality and affordable baby stroller in the market. If you wants to read some stroller related article then you can visit this website. best umbrella stroller under 200. 9 Lightweight and Best Umbrella Strollers Review PickBabyStroller com
Jul 12, 2016 | Quinny Buzz Baby Gear
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
I have 110 volts n each leg but not 220 across both why??
In a traditional North American residential electrical panel (120/240 volt, single phase), installing a single width or single pole circuit breaker, you would expect to read 120 volts from the breaker terminal screw to either ground or neutral. A double width or double pole breaker would provide 120 volts from either of the breaker terminal screws to ground or neutral AND it will provide 240 volts BETWEEN the TWO breaker terminals.
A single-width circuit breaker case that contains two handles is NOT a two pole circuit breaker (these are called "tandem" or "1/2 size" breakers). This is because a single width breaker engages only one "line" in the panel. A double width breaker will engage 2 "lines" as a triple width breaker would engage 3 "lines" of a 3 phase panel. A single wide breaker can not physically engage more than 1 "line" so it will never be able to pass 240 volts.
You must install a double width / double pole breaker to safely supply a 240 volt circuit / device.
Mar 15, 2014 | GE 20 Amp 1 In Double Pole Circuit Breaker...
In the kitchen I have replaced the light sockets a double inside the the main entrance & a single switch by the utility room the double switch controls the lights under the units & the main light,...
can't quite make out the question, but feel your fear-o-stick.
You have 3 way switch.
So 2 different switches control same light(s)
If this is true, then wires are reversed on one switch or the other, or both switches are wrong.
I've been there.
Copy following links to see illustration of typical 3-way switch wiring, and then lets do some testing.
http://waterheatertimer.org/images/GE-15312-3-way-circuit-600.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Each 3-way switch has 3 screws (plus green ground screw)
We are not going to discuss the green ground screw.
Each 3-way switch has a 'common' screw. And two traveler screws.
Th common screw should be different color than other two screws.
Or there is a marking on back of device that denotes 'common.'
Please note your common screws.
Disconnect all wires from both switches.
Separate wires for testing.
Turn power ON.
Tape wood sticks to tester so hands are away from power.
Stand on dry surface or boards. Never stand on bare ground.
http://waterheatertimer.org/images/GFCI-protection-2-402.jpg
Power is ON. All 3 switch wires are separated on both switches, so you have 6 total wires to test.
Test each wire to bare ground wire.
One and only one wire will test for live power to ground.
This is Hot wire, and it will connect to 'common' screw.
Other two wires will connect to two traveler screws.
Switch #1 is done.
Turn power ON again. Three wires are still separated on second switch.
At second switch, test each wire to bare ground. Note which wire shows power. This is a traveler wire.
Go back to first switch and flip the switch other direction.
Repeat test at second switch. Note which wire shows power. This is also a traveller wire.
There should be 2 traveler wires.
Connect these two wires to the screws that are NOT common.
Other wire connects to 'common' screw.
ADD A COMMENT for more help.
Sep 09, 2012 | Home
I have a Kingston 2.GB Data Traveler filled with data, and no instructions on how to open it to read it. Please tell me how to open. Thank you.
Your USB drive should show up under My computer. Double click on my computer and look for an icon that says something like mass storage device. The drive should be E: or above. If you double click on that icon, everything saved to the drive should show up just like any other harddrive. You can drag items to or from this drive.
Feb 20, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hi i need instructions on how to collapse the obaby apex double pushchair? please help me!!!
hi not sure if these will help they are from the apollo version most double buggies fold tthe same
just double check with images if they look the same then these will work
http://www.obaby.co.uk/manuals/Apollo-Plus-Instructions-web.pdf
Feb 07, 2011 | Toys
Java source code
* To change this template, choose Tools | Templates
* and open the template in the editor.
//package optimalcluster;
* @author CSEEXAM2008
import java.awt.*;
import java.awt.geom.*;
import javax.swing.*;
public class GraphingData extends JPanel {
double[] data = {
0.504782921308152, 1.174144134378306, 2.0933754535558546,6.2625807939548823,8.8484441414277364,10.0000003,12.908978000,14.8906789456,12.9087654567 };
final int PAD = 20;
@Override
protected void paintComponent(Graphics g) {
super.paintComponent(g);
Graphics2D g2 = (Graphics2D)g;
g2.setRenderingHint(RenderingHints.KEY_ANTIALIASING,RenderingHints.VALUE_ANTIALIAS_ON);
int w = getWidth();
int h = getHeight();
// Draw ordinate.
g2.draw(new Line2D.Double(PAD, PAD, PAD, h-PAD));
// Draw abcissa.
g2.draw(new Line2D.Double(PAD, h-PAD, w-PAD, h-PAD));
double xInc = (double)(w - 2*PAD)/(data.length-1);
double scale = (double)(h - 2*PAD)/getMax();
// Mark data points.
g2.setPaint(Color.red);
for(int i = 0; i < data.length; i++) {
double x = PAD + i*xInc;
double y = h - PAD - scale*data[i];
g2.fill(new Ellipse2D.Double(x-2, y-2, 4, 4));
g2.setPaint(Color.black);
g2.fill(new Ellipse2D.Double(x-2+4, y-2+4, 4, 4));
g2.setPaint(Color.blue);
g2.fill(new Ellipse2D.Double(x-2+6, y-2+6, 4, 4));
g2.setPaint(Color.pink);
g2.fill(new Ellipse2D.Double(x-2+8, y-2+8, 4, 4));
private double getMax() {
double max = -Integer.MAX_VALUE;
if(data[i] > max)
max = data[i];
return max;
public static void main(String[] args) {
JFrame f = new JFrame();
f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
f.add(new GraphingData());
f.setSize(400,400);
f.setLocation(200,200);
f.setVisible(true);
Feb 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
General Electric 6-Quart Slow Cooker double bowl
According to instruction book: To use Double bowls in the crock water must be used. Otherwise crock may overheat and crack.
1-Pour one quart of water into the crock. Prepare recipe according to instructions. Place food in the bowls.
2-Place both bowls into crock. Cover & cook.
To Use Double bowls in the base (without crock)
1-Prepare recipe according to instructions. Place food in bowls.
2-Place both bowls into the slow cooker base. Cover and set control knob to desired setting.
Hope this helps.
JL in CA
Jul 03, 2008 | GE 106851 6-Quart
Toys Logo
26 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
