Question about Mitsubishi Televison & Video
Mitsubishi WD-65735 replaced dlp chip with 4719-001997 ... is this wrong dlp chip?
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Posted on Nov 10, 2007
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 1099 Answers
SOURCE: mitsubishi wd 65735 - blinking green LED on front
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board just die.It can be dead at anytimes.Tries websites, to buy a refurbish power supply board for the replacement.
Good luck..
Posted on May 25, 2010
SD Tech
  • 14553 Answers
SOURCE: White spots on screen Need DMD
This is something of an urban myth....The "DMD chip" is actually the LCD display IC for the set; yes I have seen some listed on EBAY---still a myth----they are replaced (when a light engine is rebuilt in a space age lab or environment) under exacting conditions----if positioned a micron off in any direction picture will be tilted in some way---this is also not like changing spark plugs in a car, if you have a optical engine issue like spots etc, either get a rebuilt engine from Mitsubishi or buy a new set.
They usually require some parts for old engine (mounting brackets etc) be installed on new or rebuilt engine.
I did see the "chip" for another model listed on ebay today.(100.00 PLUS)
I understand the engine is expensive, I replaced a lot of them when the sets were in warranty---more Mitsubishi than any other brand with Samsung a distant second.
I am sure Mitsubishi does not offer the part for sale--they want to sell a tested rebuilt engine only.
I wish you luck but have little hope you will find a "part" other than the whole engine.
Posted on May 14, 2011
  • 373 Answers
SOURCE: How do I repair white dots/dead pixels on my 3
You have a bad light engine. It is available at for retail price of $749.10. Call 1-800-638-3328. Consumer not in business could be higher price.
Posted on Oct 24, 2011
White spots on screen need new dlp chip, want to make sure i order the correct one
maybe there's nothing wrong with the chip you can try to restart the system
May 14, 2016 | Mitsubishi WD-65735 Television
I have a Mitsubishi 65" dlp TV and the picture is green and yellow with no reds or magenta's so would that mean i need a new bulb or does it have something to do with the color wheel
It means that the color wheel or it's encoder is not properly syncing with the controller. It is therefore blanking the DLP chip on the red and blue sections of the color wheel. Clean the color wheel motor and encoder disk, lubricate the motor. This should correct the problem. There may be dirt in the opto-coupler that is reading the color wheel. Be sure to clean it with a vacuum and small brush. Regards.
Nov 28, 2015 | Mitsubishi WD Televison & Video
I replaced a new DLP chip WD 65735 in my Mitsubishi TV worked great for two weeks and now I have lines going through it
Hello, are you're you locked in the chip correctly? Here's the video on replacing it : Make sure all the screws were reinstalled correctly. You may want to pull it apart again and go though it and make sure it's locked in and the screws are tight. If they are, the new chip may be damaged.....tks
Feb 25, 2015 | Miscellaneous
How do I fix pixels on my tv screen
Usually solved by replacing the DLP chip (Google it) they cost around 180. If you have a couple hundred more I'd just go buy a Samsung LCD smart tv.
Feb 21, 2015 | Mitsubishi WD-65735 Television
I do I fix white dots on screen
Have you tuned the channel frequency tuner? Use the remote to bring up setup menu on TV, scan channel frequencies & save. If it's an old TV that can't pick up digital signals, then you need to get a digital set top box & tune to TV.
Jun 26, 2014 | Mitsubishi WD-65735 Television
Top 25% of screen darker after DLP chip replacemenat
It sounds like you got the I forget name but chip not matching your set
Only 2 to choose from Get the other one then the numbers on yours.Readiily availabe on eBay Type in your make and model Comes right up I fixed my Toshiba same way ..Don
Nov 30, 2013 | Mitsubishi WD-65735 Television
How do I repair white dots/dead pixels on my 3 year old Mitsubishi WD-65735 DLP TV?
Oct 23, 2011 | Mitsubishi WD-65735 Television
Televison & Video Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
