Question about Beko Dishwashers
Beko dishwasher light stays on when I have put salt in
Can keep putting it in but light never goes off
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
stephanos18
  • 144 Answers
SOURCE: dont know where to put the salt and how salt indicator goes off
it should have a dispenser in the bottom of the tub you just need to unscrew the lid
Posted on Mar 27, 2009
SOURCE: DuoClear 20 can't get salt light to go out unless
I have a Duoclear 25 for 3 years now. The unit has been nothing but trouble. I too have a low salt light even when the pool is tested at 4500ppm. 4500ppm for our taste is too high. The main board has been replaced for erroneous errors and now one year later the salt cell generator is non functional. The quality is poor. Furthermore most pool stores don't even know how the nature 2 works and alwasy recommend chemicals that are harmful. The company Clearwater has poor customer service.
Posted on Apr 26, 2010
news775
  • 699 Answers
SOURCE: my bosh classixx dishwasher is
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 14, 2011
bobwstacey
  • 12 Answers
SOURCE: bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
Posted on Oct 03, 2012
Reverse lights keep blowing fuse on 2002 ford sport track
You have to isolate the wiring harness that goes to the reverse light.
Somewhere in that path a chafed or bare wire is grounding out and blowing your fuse when you put the car in reverse.
Mar 05, 2015 | Ford Cars & Trucks
DW1644 Beko integrated dishwasher fault. The machine doesn't clean very well, dried bits (like sand) on dishes and glassware cloudy. It's got sufficient salt, rinse aid etc. The filter is clean. I've...
I have same problem with mine (not BEKO) what I have discovered is, it seem to be where the water hasn't run off properly before drying, so I make sure I don't put anything in flat where water can collect. It's not always possible to put things in that are not flat, but try that
Dec 14, 2014 | Beko Dishwashers
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Hi, I have a BEKO GS5323 Dishwasher that has just
sounds like the sault filter has broken. it is in the base at the bottom its a thin plastic filter type. will need to be changed.
Sep 29, 2013 | Dishwashers
Transmission won't shift out of 1st and service engine light comes on. goes in reverse and park. goes in drive , just will not shift.
Hi Cindy, As the engine check light is coming it is indicating a problem. Have a diagnostic scan carried out and let your technician determine the actual fault. It could be something to do with the state of engine tune or a defective speed sensor, but may also be a problem with the gearbox. Regards John
Sep 09, 2012 | 1993 Jeep Grand Cherokee
Salt light stays on
There is probubally an sensor in the machine that senses salt levels, it is not uncommon for and sensor to be faulty out of the box, I would contact the manufacturers on their 1-800 number nd consult with them and if be order the replacement part from them directly. Hope this helps
Sep 08, 2012 | Amana Dishwashers
HOW MUCH SALT SHOULD I PUT AND HOW AFTON
Here is a dishwasher manual search engine, they will find the Beko user manual within minutes. Just send them a search request for your model.
Aug 11, 2012 | Dishwashers
2007 CRV check engine light goes on and off
Do not pay for a scan. Take the car to a store that offers free scans and tell them you need the codes stored in history and any pending codes. Then post the codes here for help with diagnosis. Don't rep, ace parts until you have a good diagnosis.
Jul 05, 2017 | 2007 Honda CR-V
Filter light is on. I pull filter - its clean. I put filter back in - filter light goes out. I start dryer. It runs for about 5 seconds and stops
Did anyone come up with a solution to the problem, we are having the same problem, except our dryer keeps running, the filter light goes out, and when the dryer is turn back on the filter light is back on, the filter is clean.
Oct 22, 2010 | Kenmore Elite HE4 Electric Dryer
Dishwashers Logo
77 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
