System will not hold coolant, there is a hissing sound coming from the lower belt driven unit, I think is is the clutch assembly. When I push in on the pulley and clutch assembly the hissing almost stops or changes sound. I am seeking information as to its nature, is this a normal bleed off or it the unit defective and what is an average cost to repair. Thanks
  • Ken Bledsoe May 11, 2010
    You need a new compressor. And the ave bill is around 750 bucks.
  • 25 Answers
That unit you speak of is the compressor and compressor clutch if its leaking at a fitting on the compressor its not to expensive to fix but its comming from behind the clutch assy that it is the compressor shaft seal and may mean a new compressor. you can find rebuilt compressors for a couple hundred bucks. but the system will have to be serviced by a certified a/c tech because the system will need to be evacuated down to 29inches of vacume before any refrigerant can be added so to see if there is any other leaks and rid the system of all air and moisture.
Posted on Jul 31, 2009
2001 Camry 5 speed. It starts but it will not move. I can change gears without pushing in clutch. One mechanic said it was clutch and a different one said transmission is out. Which is it?
The clutch is not transferring power to the gearbox, which then is not turning, so that you can select gears without the clutch.Possibilities are
- clutch assembly has failed, possibly by the splined driven plate hub coming adrift
- clutch driven plate has become very worn and has lost contact
- slave cylinder has stuck through corrosion (assuming a hydraulic clutch) and is holding out the clutch independent of the pedal. This can be determined by watching it while someone depresses and raises the pedal.
I think it is unlikely the transmission input shaft has fractured.
Aug 14, 2015 | 2001 Toyota Camry
New thermostat, fan switch , fan comes on, still overheats . Upper hose hot, same lower hose but both are hard feels like the water is not circulating . Bad water pump, or head gasket ?
Most likely pump. Head gasket will usually put hot gases into the cooling system and will appear as bubbles in the cooling fluid container. It may also feed lubrication oil into the coolant. The coolant pump is driven by fan belts. Make sure you are not missing any belts.
Mar 09, 2015 | Cars & Trucks
Why does my radiator cooling fan quit working
I am assuming this a fan belt driven system and not an electric motor driven system like on some Fiats I have seen. Usually there is a sort of clutch involved between the belt driven pulley and the radiator fan. This is to prevent the fan from spinning (and cooling the engine) before the engine/coolant has reached certain temperature. This is designed essentially for cold climate countries. The fan should start spinning once it gets hot. If not this clutch might need replacement
May 04, 2014 | Ruud Heating & Cooling
Need to replace the coolant radiator sm put a hole in it hitting a gard rail easy removal tips
What model vehicle?
this makes a big difference as to removing the radiator.
I can walk you through it from removal to installation and purging
most cases you will need to remove the dust cover over top of the radiator first, then the fan shroud(2 bolts or clips, one on each side) , drain the system into a catch pan , remove trans cooler lines, remove lower and upper coolant lines.
if you have electric cooling fans mounted to your radiator, disconnect the wire plugs, unbolt them from the radiator (3-4 bolts)
if you have a belt driven clutch fan. Remove the tension on your belt , remove the four screws holding the fan on, and pull the fan out, then on the sides of your radiator there will be two to four bolts mounting it to the front clip, remove them then your radiator will slide right out,
to install reverse the process
Apr 29, 2014 | Cars & Trucks
How do you change a clutch cable in a 1989 mustang 5.0l 5 speed
Hi, procedure from autozone.com pasted below. Please let me know if you have any questions, and thanks for using FixYa.
CAUTION The clutch driven disc often contains asbestos, which has been determined to be a cancer-causing agent Never clean clutch surfaces with compressed air. Avoid inhaling any dust from any clutch surface. When cleaning clutch surfaces, use a commercially-available brake cleaning fluid.
REMOVAL & INSTALLATION
  1. Lift the clutch pedal to its upward-most position to disengage the pawl and quadrant. Push the quadrant forward, unhook the cable from the quadrant and allow it to slowly swing rearward.
  2. Open the hood and remove the screw that holds the cable assembly isolator to the dash panel.
  3. Pull the cable through the dash panel and into the engine compartment. On 5.0L engines, remove the cable bracket screw from the fender apron.
  4. Raise and support the vehicle safely using jackstands.
  5. Remove the dust cover from the bell housing.
  6. Remove the clip retainer holding the cable assembly to the bell housing.
  7. Slide the ball on the end of the cable assembly through the hole in the clutch release lever and remove the cable.
  8. Remove the dash panel isolator from the cable.
To install:
  1. Install the dash panel isolator on the cable assembly.
  2. Insert the cable through the hole in the bell housing and through the hole in the clutch release lever. Slide the ball on the end of the cable assembly away from the hole in the clutch release lever.
  3. Install the clip retainer that holds the cable assembly to the bell housing.
  4. Install the dust shield on the bell housing.
  5. Push the cable assembly into the engine compartment and lower the vehicle. On 5.0L engines, install the cable bracket screw in the fender apron.
  6. Push the cable assembly into the hole in the dash panel and secure the isolator with a screw.
  7. Install the cable assembly by lifting the clutch pedal to disengage the pawl and quadrant. Then, pushing the quadrant forward, hook the end of the cable over the rear of the quadrant.
  8. Depress the clutch cable several times to adjust the cable.
May 07, 2011 | Ford Mustang Cars & Trucks
How to change water pump 1991 plymouth voyager 3.3 liter v6
PLEASE DON'T FORGET TO RATE:
Water pump-3.3L and 3.8L engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the serpentine belt.
  4. Raise the vehicle and support safely. Remove the right front tire and wheel assembly and lower fender shield.
  5. Remove the water pump pulley.
  6. Remove the 5 mounting screws and remove the pump from the engine.
  7. Discard the O-ring.
To install:
  1. Using a new O-ring, install the pump to the engine. Tighten the mounting bolts to 21 ft. lbs. (30 Nm).
  2. Install the water pump pulley.
  3. Install the fender shield and tire and wheel assembly. Lower the vehicle.
  4. Install the serpentine belt.
  5. Remove the engine temperature sending unit. Fill the radiator with coolant until the coolant comes out the sending unit hole. Install the sending unit and continue to fill the radiator.
  6. Connect the negative battery cable, run the vehicle until the thermostat opens, fill the radiator completely and check for leaks.
  7. Once the vehicle has cooled, recheck the coolant level.
Sep 13, 2010 | Plymouth Voyager Cars & Trucks
My 96 thunderbird gettin hot
is your fan clutch kicking in? It could be bad. crab the fan blade and try to move it back and forth. If it moves more than minimal you will need to replace your fan clutch.
Oct 08, 2009 | 1996 Ford Thunderbird LX
CHANGING A BELT ON AMANA MODEL # ALW990EAW/PALW990EAW
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Amana LWA90A
Belt
Remove sole plate and beater bar.
Remove control knob by prising between yellow plastic side of knob and casing using wide bladed screwdriver.
There three torx headed screws holding the clotch assembly in place. Two are visible but the third is accessed via a circular access holein the main casing.
When these three screws are removed the clutch assembly can be pulled out. the thinner belt driven by the motor needs easing over the motor shaft.
There are two screws holding the end plate onto the clutch assembly. remove these, twist the end plate and remove. note where the fibre clutch plate and the metal plate fit and replace this belt.
On opposite end prise off spring washer and this assembly comes off the reveal the belt.
Refitting is the reverse.
Have a look on you tube and type in replacing clutch on Dyson DC4 as there is a 10 minute vidio that is quite good!!
Hope this helps!!!!!
Dec 12, 2007 | Vacuums
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
