Question about Coffee Makers & Espresso Machines
I have a KCM0402CU Coffee Maker and one of the internal cables was eaten by bugs. I cannot open the top cover to access the terminals. Can you please assist me on how to disassemble it?
  • 33 Answers
SOURCE: repair part for Hamilton Beach Eclectrics 40210 12-Cup Coffee Maker
try this
for coffee parts needs
http://www.abtecparts.com/hamilton_beach_coffee_maker.htm
thanks
please rat eme if you found this helpful
eric
Posted on Feb 16, 2009
SOURCE: stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Posted on Feb 23, 2009
  • 11 Answers
SOURCE: Bloomfield Koffee King coffee maker
there should be a hose connecting the hole to the top of the water resevoir for venting (water expands when heated and the tank should always be full). If it is connected to a source of water (hot water on tap/ push to brew) it could also be a leak in the coil for the water on tap or the solonoid valve fo push to brew.
Posted on Dec 01, 2009
cmccune04
  • 213 Answers
SOURCE: how do you disassemble the plastic cover off a
Pretty tough. You need a long phillips and flat head screw drivers. And you have to undo the screws then pop the plastic clips while pulling back on the top (hard to explain)
If you need parts here's where to go:
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Posted on Apr 18, 2010
  • 6 Answers
SOURCE: Karcher 620M, how do I get access to cable
gday mate just did one split yellow case sealed lead pullsout pry out with screwdriver nowive just to find where to buy one
Posted on May 08, 2010
Gaggia Platinum Vision no power
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Jan 22, 2013 | Gaggia 74845 Platinum vision coffee maker...
Top cover for keurig b70 coffee maker
Not good. Its broken for good now.
Nov 21, 2012 | Keurig B70 Coffee Maker
I am Trying to Service a Vienna Saeco Coffee machine. I have removed the top covers and am trying to access the wiring under the heater and other parts for which I need to remove the chassis from the body....
-2 Phillips screws on the front (left and right under the fascia)
-1 torx in the back of the machine, under the water tank
-Hot water/steam knob that has to be removed: There is a clip that can be pressed with a tiny screwdriver (with the front door opened) which will let you pull the knob out.
Once this is all removed, you need to push with a screwdriver in a small whole from under the machine, beside the power cord. Pushing hard from one hand and pulling the whole thing up with the other should do it.
Jan 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Need instructions
Here is the website for all the Gevalia Product Manuals.
http://www.gevalia.com/Gevalia/customerservice/product_manuals.aspx
Good Luck:-)
Oct 11, 2008 | Gevalia Coffee for Two 85188 Coffee Maker
Throws Breakers
Check the power cord for damage, and repair anything you find.
If confident enough, open the unit up and inspect all the internal wiring - check for chafed wires and for terminals that have come undone or that are touching anything they aren't obviously meant to.
Check the unit hasn't got wet inside - mop dry then leave to dry out properly in warm air for a couple of days if it has.
If that doesn't throw up anything obvious, then you're probably looking at insulation breakdown of some component (my money would usually be on the element). For a unit like this, I doubt it's economic to start buting spare parts, so you're probably better off buying a new coffee maker.
Good luck
A.
Feb 23, 2008 | Bunn NHB Coffee Maker
Coffee maker won't start and just beeps when plugged in
The door on the top is not closed properly. When you open the top door(cover),you will see a button that is located on the top of the grinder cover. that is a switch that tells the coffee maker that the door is closed and can safely make coffee..please check that all parts are in place and top door(cover) is closed comepletly. good luck.
Aug 19, 2006 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
