Question about Dryers
Dryer won't turn on, tried unplugging for a bit hoping to reset but no luck
3 Suggested Answers
MY REPAIRMAN
  • 61 Answers
SOURCE: (2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Posted on Feb 22, 2012
orka2911
SOURCE: dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
I tired the reset on the over temp. Did not work. How do I check the igniter/ gas valve and thermostat?
Posted on Jun 21, 2012
Dryer won't dry clothes
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Nov 09, 2012 | Dryers
Dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
Apr 26, 2012 | LG DLG5932W Gas Dryer
Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Mar 10, 2012 | Maytag Dryers
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer won't turn on
turn the breaker on and off.If the dryer is electrical it should be a double breaker (2 switches connected with a small bar across)
Unplug the dryer and plug in after 10 seconds - might reset the electronics
dryer has thermal cutouts for safety so leave it unplugged for 1 hour see if that helps. If it starts and quits again calling service is best solution. We are talking lots of voltage here and fire is not an option
There are internal fuses as well If they blow you definitely have a problem
Todays dryers are more complex and they do need somebody qualified
to service them safely
good luck
Feb 06, 2012 | LG DLEX2901V Dryer
A zipper from a comforter is lodged between the moving drum and its housing causing a possible drag on the rotating drum. not sure how to dislodge zipper or remove drum to access
The whole drum should move a bit. Try turning it by hand and pushing back on it (or pulling forward). Also, you can try lifting up quite hard (drum is free to move about 1/2" in all directions the way most are set up. I havn't seen this specific unit but it is worth a try.
Otherwise, I think there is a set of screws around the top perimeter holding the top deck on. Remove that and you will have a better view of what moves and by how much.
Remember )
1) Unplug the unit before unscrewing anything.
2) Make sure everything is put back as you found it before putting lid back on.
Also, you won't break anything by only taking it apart to look. Have fun doing it and good luck. Hopefully they used standard screws instead of some tamper-resistant fasteners that German manufactures are using a lot of lately (Braun, Krups, Bosch, ...).
Most hopefully, you can get it un-stuck by shifting the drum a bit.
-Mark
May 02, 2011 | Bosch Nexxt 500 Dryer
My LG Tromm electric dryer has no power. I turned it on and it ran for a few min. and just turned off. I have tried the breaker and also unplugged it and plugged it back in but no luck. Is there a...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 08, 2011 | LG DLE2514 Electric Dryer
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Oct 06, 2010 | Kenmore 82822 Electric Dryer
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
