Question about Garden
My electric snow thrower won't start. - Garden
  • 10865 Answers
SOURCE: snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Posted on Jan 23, 2009
  • 661 Answers
SOURCE: snapper electric start snow thrower won't start
If the engine has a float type carburetor, remove the float cover and see if the float is hung in the down position. If so free it up and make sure it will now operate freely up and down. If not and the bowl is full of crud, you will have to remove and clean the carb.
Posted on Mar 13, 2009
  • 430 Answers
rebuild the carb.
Posted on Nov 30, 2009
  • 120 Answers
SOURCE: Hello, My Troy Bilt Snow Thrower will not start
Check for fuel and make sure the fuel shut off valve is open to allow fuel flow. If you left your gas in for the summer, it may have gone bad and caused your carburetor to clog up. A cleaning will be required.
Posted on Dec 07, 2009
  • 10865 Answers
SOURCE: craftsman 8hp snowblower starts but will not stay
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Posted on Dec 19, 2009
Sears model 1150 snow thrower how repairing the electric connecter for sears model 1150 snow thrower
It's just a simple AC pronged piece. You can buy the actual piece from Sears OR you can buy an Electric Line-cord and wire it into teh plastic box where the Push button 'Start ' switch is.
Mar 01, 2015 | Garden
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
My neighbor's gardenway snow thrower by troy bilt electric start won't start.
check the oil level. There is a safety device in a lot of small engines that will either kill the motor or not allow the motor to start if it is low on oil
Dec 30, 2012 | Garden
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
