Question about NordicTrack Exercise & Fitness
Nordictrack 1000i. Every thing works except motor will not run. I checked motor with DC battery and runs fine. Is it possible still the motor? Any ideas what I can test next & how to do it? Thank you
  • NordicTrack Master
  • 6,694 Answers
The motor control board would be faulty.
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 20, 2016
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 103 Answers
SOURCE: Nordictrack EXP1000i stopped in the middle of program
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt. Good Luck, Tim
Posted on Nov 13, 2009
2manyhobbies
  • 129 Answers
SOURCE: I have a NordicTrack c2200. I find that the tread
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Posted on Dec 30, 2010
ercupa190
  • 12223 Answers
SOURCE: tr2 motor will not run,used 24v battery to test motor,runs ok.what could it be
Dear Sir:
Try to run the software calibration for easy diagnose and troubleshootin.
See my personal TIPS FOR HELP.
However the main motor board 2) main motor can be faulty.
measure the input voltage to the main transformer. 2) measure the output from the main motor board.
sincerely. God bless you
Posted on Apr 09, 2012
ercupa190
  • 12223 Answers
SOURCE: treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Posted on Jun 03, 2012
I have a Nordictrack A2250 NTL806.0 moter working fine check the reel switch that fine but. problem is when you start the track it run for like 2 sec then stop.ever thing else works fan work goes up a
This sounds like there is an inadequate power supply to the panel circuit. Check that the batteries are properly seated in the battery compartment. Also, check that the batteries are not low or dead, as it could be that they are seated properly but not providing the necessary charge to the panel when you switch it on.
Jan 24, 2015 | Nordic Track Exercise & Fitness
Pro-form 450cx
If the battery + and - polarity are proper and the motor operates on DC current; it should work OK. The reason a motor fails is if the coils burn out, and that can happen if the polarity is reversed in error, alternating current was applied to a DC device, or a Power Surge damaged the components.
Feb 26, 2014 | Exercise & Fitness
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
When I turn on my nordictrack e4400 it runs for 1 second and then stops
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Mar 22, 2011 | NordicTrack E4000 Treadmill
NordicTrack 2500 R Treadmill Doesnt want to start rolling, even though the program appears to be running on the display. And on the rare occasion it does start, it stops again after 2-3 minutes.
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Jul 15, 2010 | Nordic Track Exercise & Fitness
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
