Try the small round reset button top left, and then re-program:
Manuals, including troubleshoot pdf, and wiring on following link:
http://waterheatertimer.org/Digital-control-centers-and-manuals.html#PE153
Install type 2 whole house surge protector or type 1 surge arrester to protect timers, lights, electronics. Make sure household grounding is appropriate, bond outdoor equipment to a ground wire that goes into dedicated ground rod:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Lost the instructions need help setting it up for
Here ya go:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Testimonial: "great instructions, thanks"
SOURCE: Intermatic Pool timer will not turn off... I have
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
SOURCE: My Intermatic pool timer is not working. It is not
Also open following link
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
